Injector timing switch help !!!
Old 09-11-2013, 04:37 PM
Yodalife12's Avatar
93 22re pickup has a hard time starting up usally when cold replaced the cold start injector and still does it. Is there a way to test this sensor before i throw money in the dark ?
Thanks
Old 09-11-2013, 08:11 PM
ericacymcdonald's Avatar
Check out 4crawler.com
Old 09-12-2013, 07:33 AM
Gamefreakgc's Avatar
The manual is all knowing...
http://personal.utulsa.edu/~nathan-b...ne/39colds.pdf
If it's bad, pull a good one from a junkyard. These silly things are $200 new, $7 at a junkyard.
Also, pull out the actual injector and clean off the nozzle, it might be clogged.
Old 09-12-2013, 08:58 AM
Yodalife12's Avatar
Will do thanks man
steve miller
10-10-2015 01:40 AM
bryan34w
07-06-2015 05:53 PM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Injector timing switch help !!!
