Injector cutoff when braking and sudden jerking
Old 10-31-2010, 07:14 PM
DupermanDave's Avatar
I think I have all of my truck patched up and I have no more issues except this stupid EGR temperature sensor. I'm fixing up the bugs one by one and this next one has been happening since I got the truck. Whenever I'm coasting with the transmission in gear, whenever I apply the brakes the injectors are supposed to cut off and they do. I can tell they're cutting off because I'll be cruising at a good steady speed without giving it gas and as soon as I barely tap the brakes, the injectors cut off and that's when the truck jerks to slow down. It's hard to describe, but I can get a video if you guys want.
Basically I'll be coasting with the RPMS at a steady 2500...keep on coasting with my foot off the pedals...RPMS slowly decrease from 2500 to 2300....I step on the brakes and the truck jerks and the RPMS drop dramatically. I saw another post similar to this, but that one sounded more like a dashpot issue. This isn't related to the dashpot because the throttle body is fully closed at this point. I can let the truck coast for 5 seconds, 10 seconds, 15 seconds, 20 seconds and it's all fine up until I press the brakes.
Any ideas where to start looking?
Old 10-31-2010, 09:19 PM
Junkers88's Avatar
Just to get a baseline to start chasing this, what does your rig idle at when it's warm?
Old 11-01-2010, 10:06 AM
When the rig is warm I've got it idling at about 850-900 RPMS. At a cold idle it's about 1500.
Old 11-11-2010, 01:37 PM
Looks like with the TPS unplugged, the cutoff doesn't happen. jhdfjklhsadljkfhwekrlhdmnbzxcvhsgdiuwareyhiashgdbf sdghjsdf. Bad or mis adjusted TPS. I'm sick of this POS TPS.
Thread closed. I'm buying a new TPS and seeing if my dad, the non-mechanic but good electrician, can adjust it for me.
Tonetrk
08-06-2015 10:06 AM
Esibnitsud
07-30-2015 08:19 PM
pyramid
07-30-2015 10:05 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Injector cutoff when braking and sudden jerking
