injector cleaning ?
injector cleaning ?
I have a kit that i use on my ford and chevy in the past, it is basically a high pressure hose that screws onto the fuel schrader valve and after pulling the fuel pump fuse and plugging the regulator hose, you start the truck running it off a can of fuel injector cleaner (usually runs for about 4-5 minutes off the can).... do they make a schrader valve that will work on the 22RE fuel rail?
highway
highway
found it:
http://tijil.org/Scion_Docs/Scion_TS...6/pg01105r.pdf
just got to find the adapter or adapter pack
Toyota Adaptor Pak 00289-1PF00-02
TYG S–Line Device 00289–1PF00–01
Highway....what do you mean you have to find the adapter or adapter pack?
Aren't both the Toyota Adapter Pack and the TYG S-Line Device available at the dealer?
What is the difference between the two?
This sounds like a pretty cool method of cleaning injectors, I might give it a shot.
Thanks.
Thanks.
didn't know the dealer sold the adapters. with my kit the hose only fits on the schrader valves on dodge,GM,ford's, i just need an adapter to fit on my hose is all.
mine is made sorta like this one
Blamalam
03-12-2022 07:34 AM
Koolbananass
08-12-2015 01:59 AM
pyramid
07-30-2015 10:05 AM
