Inclinometer swap
Old 08-22-2013, 09:55 PM
Oregontoyotas's Avatar
Inclinometer swap
So I have an 85' toyota pickup sr5 full I. Options and the only thing it doesn't have is the inclinometer. I was wondering if anyone knew if the sr5 pickups came with the connectors Allredy installed? I got an 87' 4runner for $300 and it had one. Just didn't know if anyone has done the swap them selfs thanks
Old 08-23-2013, 12:46 AM
-City Slicker's Avatar
the wire attached to the inclinometer powers the lights.
otherwise it needs no external power..
85-88 should have female plug somewhere under dash.
some come with a mounting bracket.
w/ that it looks like you screw directly into the dash..
yikes.
i want one.
good luck.
Old 08-23-2013, 11:26 AM
yikes.
i want one.
good luck.
That's what I was thinking. If not I can just do some Wiring... Thanks!
Old 08-23-2013, 07:52 PM
RSR
RSR's Avatar
Pictures please with whatever you do. I've been wanting one...
Old 08-23-2013, 08:15 PM
paintwerk's Avatar
My 86 base model pickup had the wiring under the dash pad.
Its a pretty simple install, as long as you get a inclinometer with the bracket. Pull off the pad and drill the mounting holes, which are already marked by a metal bracket on the backside of the pad.
One thing to keep in mind is that deluxe interior models have a different dashpad, so in some cases fitment may not be perfect.
My inclinometer has a slight mismatch because of this reason. However I wanted it for function, so it doesnt bother me, and most people probably wouldnt even notice.
Old 08-23-2013, 08:53 PM
YotaWoRx's Avatar
I swapped the whole dashpad with the inclinometer into my truck.....
Old 08-23-2013, 10:34 PM
Was it very hard? All the wires for lights there? How long did it take you? My dash is cracked in my truck so that is the same plan!
Old 08-24-2013, 05:04 AM
maco35's Avatar
This might help. www.yotatech.com/f116/87-pu-dash-removal-how-98660/
Old 08-24-2013, 05:06 AM
maco35's Avatar
https://www.yotatech.com/forums/f115...emoval-189633/
Old 08-24-2013, 06:42 AM
YotaWoRx's Avatar
Not hard at all. Took me about 4 beers worth of time lol. All the wires are there, even for the inclinometer light.
Old 08-26-2013, 02:16 PM
cwapface's Avatar
I found a plug tucked under the dash behind the glove box that is the same shape as the inclinometer light, but it's not for lighting so it didn't do anything. There is a part that some trucks need that is just a Y-harness to split the climate control lighting into 2 plugs, but even if you could find it at a dealer it would be $$$. Just tap into the climate control lighting yourself and it is really easy.
When testing, don't forget to double check the "light off" button on the inclinometer itself. Many d'oh moments caused by that little guy
Old 08-26-2013, 02:35 PM
Yes it took me an good 5 minuets to figure out was going on because I still wanted everything to light up. So I went to the other truck I have and looked at it and the y harness was there. Pretty easy to remove the dash after you find all the bolts and screws.
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
AkitaDog
09-01-2015 08:05 AM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
GeoRoss
07-24-2015 03:03 PM
Quick Reply: Inclinometer swap
