Im looking for idler arm/ IFS upgrades
So since I have recently decided to stay with my IFS for a bit longer and armor up before a think about SAS I need some advice. In my opinion the idler arm is the weakest link in the IFS chain (I have replaced 3 already). The thing gets out of whack on almost every trip out, sending everything else down the line out of order.
It has caused me to wear tires un evenly and trash wheel bearings and tie rods. I guess it is not helping that im running 33s on completely stock IFS and soon I want to move up to 35s.
So what im looking for is some bigger stronger better IFS components starting with the idler arm. I bend the thing up so bad it will hit the frame. My frame has silver grooves where it rubs and all I can do is bend it back with a pry bar, that lasts about a few speed bumps.
So If i want to continue with my IFS I need to get this thing stronger. Im also open to any other IFS upgrades that will help me beef it up for the trails ( please no one tell me to do a bushing rebuild kit thats not going to help).
I have had more issues with the bushings wearing out than bending the arm. Doing the bronze bushing replacement has fixed mine. As I see it, you have two options for the idler arms on our rigs:
- the downey brace and the bronze bushings (and know it might still break)
- the Total Chaos (and be done with it forever)
go with the brace, but replace the stupid grade 3 hardware they use. And when you install it, make sure you really crank it down and bend the brace around the arm.
Yet at the same time looking at all this SFA is going farther and farther back in my mind. The only reason I was hard up for it before was not because where it could take me but more the idea of durability. looking at this since im finally going to have money to do whatever.
Has everyones experience with the brace been sufficient? and if i did that I would also have to do the brass bushing replacement.
*Edit* Nevermind links are for coilover 4 runners im stupid. Still same questions otherwise.
I've ran the Downey brace for YEARS and it worked great. Unfortunately, I just replaced all the front steering stuff and my new ider isnt the same as the OEM one. So, we'll see how long this one lasts compared to the orginal one. I did replace the bushings once, but it didn't really help because the bores the bushings sat was so wollered out it still was loose. Of course that idler arm was 22 years old!! lol!
Funny but I would rather spend the money on sliders and a winch at the moment.
Not to mention I can run bigger tires with my gearset and IFS if I wanted too. I dont feel like throwing away my front diff to swap right now. Im just looking for a few things to get me by while I try and fix up some armor and a winch that im going to need IFS or not in the future.
The idler arm is the only thing giving me an issue, I thank the helpful people who solved my problem.
I dunno mine rides great. I couldnt handle driving a SFA everyday. Just make sure your idler arm is in good shape and your pitman arm. Because once those wear your whole tie rod assembly + relay rod will start to move back and forth, alot..
after two years and a few idler arm rebuilds, my pitman arm has started to wear out..
http://www.custommachiningusa.com/Specialty_Items.html
And I answered my own question I read around and found out that I cant rebuilt any of the after market idlers only the toyota one.
Hopefully when I head back to cali to get my truck next week I can find the original toyota one in the parts pile. If not I might just spend the 200 extra dollars and buy the TC one.
Adding it up the downey brace and brass rebuilt kit is around 100 on its own then finding another toyota idler from a junkyard I dont know how much that would be 20-40 bucks maybe? then again the TC idler is like 370.......well atleast I have a few more weeks to figure it all out.
http://www.sdori.com/SDORI_Products.html as well, although his bushings are for an aftermarket arm ONLY, and only 1 particular model.
I bought another idler arm after figuring out that my original was rusted beyond repair.
It looks like the factory but itsnt the same size, I can't find bushings to rebuild it with!!!
But it fits with the brace.
When you crank the brace on, be aware that once you have to remove it, its gonna be fun. You will need to use a vice and bend the brace back out.
Either way I will let yall know what I did sometime around next month when I have the truck back from california and my tools back to do it all. I have atleast a month to talk it over with my brain.
They are both good options really, what I think its going to come down too is if I have found the sliders I want to spend the money on by then.
thanks for all the help everyone!
If you have the money. Go for the TC idler. Its a one time buy that you wont ever have to replace. The weak idler is one of the biggest drawbacks to keeping IFS.
