im beating a dead horse
I posted before about a headlight upgrade about hids and I read I needed a wiring harness.. well after doing a search I found out I can get e-code headlights and run an h4 bulb I found these on amazon
im wondering are these just plug and go or do I need a harness for these also
AutoPal Euro Clear H6054 7x6 Inch 200mm Headlights Pair H4 Bulbs Non-Sealed H6014/H6052/H6054 : Amazon.com : Automotive
Not to be a jerk, which are abundant on public forums, but on the first line under "Product Features"
-Fits H6014/H6052/H6054 sealed beam socket - Plug and Play=
According to Amazon anyway, looks like plug & play. Id be wary of quality though. Ive seen some crappy amazon/ebay lights
Search for "H4 conversion". Also "H4 conversion harness" for plug-n play harness. Also go to 4Crawler's website and look for same.
Link on my sig compares voltages drops between stock and upgraded and details how I did mine using only one additional relay and thicker wires.
well I found some these on ebay http://www.ebay.com/itm/200mm-H6054-H4-EURO-CONVERSION-HEADLIGHTS-KIT-/330897426583?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0b060897&vxp=mtrI read in some posts that u don't need the harness and that 55/60 watt bulbs would work
Correct, you do not need the harness, those fixtures are plug- n play. The harness is an upgrade to minimize voltage drop (meaning power loss) in wiring as explained in my post, as well as other posts.
Not to be a jerk here as well, but I rode with a friend the other night who was showing me his best awesome top of the line lights that he had to run all crazy wire harnesses for, and they had a cool blue tint and shoot way out and really wide etc. etc.
My 2 year old foggy sealed beams did almost the same
To each is own though, do as you please!
my $0.02 is to leave it alone and just get some upgraded sealed beams, as those fancy bulbs seem to get expensive when stuff goes wrong.
But I know nothing about headlights, so I cant really answer your question.
I was going to get something like for my 88 sr5 before I realized that POS I sunk all my time and money into should be on fire in my yard right now, or in a junkyard.
I don't know how they are compared to other lights, because lke I said I don't know anything about lights but they seemed to be an upgrade.
http://www.summitracing.com/parts/grm-09-1081/overview/
I guess you just plug an H4 bulb into it?
EDIT*** I guess that's pretty much what you're asking....if the wiring harness has to be changed to accommodate the H4 bulb
The stock wiring and wire routing is not even good enough for the stock bulbs, so you are better off upgradeing the harness and going with a "proper" relay system than spending cash on bulbs you won't be getting the maximum from.
You should check out RAD's link on the harness.
well im getting these http://www.ebay.com/itm/200mm-H6054-H4-EURO-CONVERSION-HEADLIGHTS-KIT-/330897426583?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d0b060897&vxp=mtrand a harness but what harness do I need I see 4crawler has like 3-4 different 4h ones
smilen724
13
11-08-2015 04:11 PM
Toys4parts
09-26-2015 01:56 PM
