Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
Ignitor, rpm sensor anything to worry about?
I posted this earlier so here it goes again. I have code 6 showing up and was wondering what I should do about it. The truck still seems to run fine. I jsut don't want to get stranded. Code 6) Engine Speed (RPM) sensor, circuit Ignitor or circuit, distributor, ECU. What could have caused this and how do I fix it?
| Sponsored Links |
#2 (permalink) |
It means there is a signal issue in the ignition system somewhere. It's going to be hard to find unless the truck quits running or it constantly throws the code and you have access to an oscilliscope.
Most mechanics would start replacing parts (guessing) until it goes away. I don't know anything about the engine speed sensor, however. HAve you looked at the factory service manual in regard to debugging this code?
__________________
http://www.22REturbo.net |
#3 (permalink) |
No, I have not looked at the FSM. However, I know a mechanic with a oscilliscope I think. What he has is something that looks like a computer that has a graph of how the engine runs. It looks like a sin curve. Would that be able to tell me what is wrong?
#4 (permalink) |
It'd be able to show you the ignition signal. If something was getting spiked, had noise, or was producing a bad signal you'd be able to see it. It requires some electronics experience.
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| RPM help? after changing o2 sensor | brokefence | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 06-01-2007 04:22 AM |
| Ignitor and knock sensor? | 4mydogs | 86-95 Trucks & 4Runners | 21 | 03-07-2007 10:46 PM |
| Selling my truck - should I worry about this? | Cardiac | Off Topic Talk | 3 | 05-20-2006 02:24 PM |
| should i worry about this rust? | KevyWevy | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 12-02-2003 05:40 PM |
| Are the Water Temp Sensor and ignitor for 22 R-TE compatable with 22 Re ? | Lonny007 | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 09-29-2003 08:18 PM |
