Ignition/starting problem
Old 12-05-2008, 02:00 PM
Duartizzle's Avatar
Got a new problem developing with the runner. Yesterday I went to start her up, turned the key, it kind of acted as if there was a dead battery. All the lights on the dash lit up, but it wouldn't even attempt to crank over. Then last night I went to take the key out of the ignition and it wouldn't come out of the ignition. I kept having to start the car, and try and take it out. It finally came out. Are these 2 problems linked? If so, what is the cause and solution? Thanks
Old 12-05-2008, 02:55 PM
abecedarian's Avatar
may be linked. if the key does not fully return to off and allow you to remove it, the ignition switch may be partially completing a circuit causing a drain on the battery.
can not be sure though unless you can test the switch.
otherwise, since you got the key out, if you have no further problems in the future, it may have just been the keyway hanging up causing a drain on the battery.
Old 12-05-2008, 11:43 PM
Duartizzle's Avatar
Well I played with it again, turned the car on, and again couldn't get the key out. I am starting to think its the switch itself.
Old 12-06-2008, 12:26 AM
Ed H.'s Avatar
make model year?
Old 12-06-2008, 09:12 AM
Duartizzle's Avatar
93 v6 runner
Old 12-06-2008, 09:42 AM
Bako88's Avatar
Those things do wear out. Mine works except that you can remove the key in any position. The key almost falls out. I think I had to replace the switch on my wife's '94 Bronco (it's long gone) once.
Old 12-06-2008, 10:24 AM
4runner gage's Avatar
have the same problem all u have to do is move the shifter all the way to the right i have the same year hope this helps
SubiKing
08-21-2021 03:57 AM
theking11863
03-19-2016 09:36 PM
Logz808
07-26-2015 07:09 AM
Jonny246
07-24-2015 12:37 PM
kyletbert
07-17-2015 11:39 AM
Quick Reply: Ignition/starting problem
