YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 10-11-2008, 02:20 PM   #1 (permalink)
huntnfreak's Avatar
Send a message via Yahoo to huntnfreak
Ignition problem no start
I have a 90 4runner 3.0 and i have replaced the starter and cylanoid on the starter and the truck had no problems until today i drove the truck all day start and stop at the stores and then at end of the day it took about 10min. to try to start it. i didn't here any noise outside of the truck no clicking sound like before this happened. So i was woundering if there has been problems for the ignition cylinder or the ignition switch. Please need info.
Thank you Tony
huntnfreak is offline
Sponsored Links
To remove this ad, register today!
Old 10-11-2008, 03:17 PM   #2 (permalink)
just a 22re's Avatar
Send a message via AIM to just a 22re Send a message via Yahoo to just a 22re
did you check to make sure the wires are tight on the starter and battery my battery cable got loose on me and did the same thing
__________________
GO TEAM LAZY!!
my name is ALLAN
yeah its a 22re 5-speed 4wd 1987 4runner with a cam, snorkel, welded rear
Quote:
Originally Posted by SwampThing View Post
Going wheeling and going swampthinging are two totally different things. Wheeling is doing something with the expectation of having fun in the process. Swampthinging is doing something and knowing you'll probably end up in a hospital in the process.
http://www.yotatech.com/misc.php?do=flashchat
www.myspace.com/whatsadisplayname
just a 22re is offline
Old 10-11-2008, 05:47 PM   #3 (permalink)
huntnfreak's Avatar
i will check the wires 2nite, I talk buddy of mine and he said to check to starter relay.
Old 10-11-2008, 07:12 PM   #4 (permalink)
fireman1559's Avatar
are you sure its your starter? my truck died its the 3.slow and my ignitor went out and it wouldnt start it would just kinda shake a bit then stop
__________________
FIRST-truck 1990 SR5 pickup 4x4 cracked head ran for a year had over 360,000miles with the 3.0L v6
SECOND-truck 1997 ford f150 with the 4.2L v6 bearly 100,000 miles when it runs i got 8mpg WHEN it ran
THIRD-truck 1990 SR5 pickup 4x4 3.0L v6 150,000 miles runs like i bought it in 1990
life lesson ford sucks toyotas rock!!
fireman1559 is offline
Old 10-11-2008, 08:35 PM   #5 (permalink)
huntnfreak's Avatar
I just replaced the starter a month ago. because of this problem, but it was making clicking sound coming from the starter. The truck is starting just fine now so i think it might be maybe the ignition relay or the ignition switch. If it was the ignitor would it still start every so often.
Old 10-12-2008, 08:11 PM   #6 (permalink)
nope it wouldnt mine just sat there it worked fine up until it died it will go out slowly my truck acted up for like a week like die and come back everynow and then then one day it wouldnt start
__________________
Old 10-12-2008, 08:16 PM   #7 (permalink)
abecedarian's Avatar
battery?
__________________
Quote:
Originally Posted by Obama 'Ironman' Hussein
I want to ensure that everyone has the same capabilities off-road. Whether from the factory through high-dollar investments, from the aftermarket or by the hard work of the American backyard mechanic.
Therefore, I am taking some suspension travel from the more capable, more invested, more costly vehicles and transferring ... no ... redistributing that suspension travel to the other less fortunate vehicles. I am doing so in order to guarantee that everyone has the same opportunities off road.
abecedarian is offline
Old 10-14-2008, 05:36 AM   #8 (permalink)
huntnfreak's Avatar
battery is good
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
mystery ignition problem orangev8z 86-95 Trucks & 4Runners 4 03-11-2008 01:29 PM
ignition problem (I think) tim_12345 86-95 Trucks & 4Runners 2 10-31-2007 10:33 PM
84 pickup ignition problem? Mister Willie 84-85 Trucks & 4Runners 1 04-09-2007 02:45 PM
Starter Problem or Ignition Switch Problem? highplainsdrifter 95.5-2004 Tacomas & 96-2002 4Runners 0 11-12-2006 05:14 PM
No Start Condition: Ignition and Coil Test Info for 3VZE (89-95) Brown 95.5-2004 Tacomas & 96-2002 4Runners 0 05-10-2003 11:14 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
