Ignition
Old 12-21-2014, 02:33 PM
Tuckerrobinson28's Avatar
Ignition
I have a 94 3.0 vze
My computer is getting good signal from the pick up in my distributor, but my computer isn't sending any signal to my igniter. Please help! I tried a spare computer, it's possible that they are both bad but I really don't think that's the case.
Old 12-21-2014, 06:53 PM
RJR
RJR's Avatar
Which signal did you check from the distributor to the ECU? There are 3 signals that are required, an NE signal (24 pulses/revolution) and two G signals (4 pulses per revolution). If any of those are missing the ECU won't generate a spark.
Here's a link to an autoshop101 article on the Toyota ignition. For the '94 3vze, look at the ESA system on page 5.
http://www.autoshop101.com/forms/h23.pdf
Other things to check:
- What's the voltage at the ignitor? If it's stuck low it's possible that the ignitor itself is shorted.
- Verify continuity of the wiring between ECU and ignitor.
Old 12-22-2014, 06:45 AM
Ignition
Sorry I meant to say I tested all the pickups in the distributor and checked all three signals going to the ECM,
And I'm almost positive my igniter is getting proper voltage but I'll check that again. Thanks for the help
Kamaloha
10-16-2015 05:13 PM
zombie_barbarossa
10-02-2015 10:54 PM
Rerun
3.4 Swaps
10-01-2015 12:24 PM
voiddweller
09-28-2015 11:21 PM
JHalcyonM
09-14-2015 01:10 AM
Quick Reply: Ignition
