IFS Suspension and questions
I have a 88 22re 4runner and i'm new to the 4runners, as well as ifs. This truck is my daily driver and will be until i get back on my feet. I work at a machine shop were we scrap alot of different metal, so with that being said i get my material really cheap. The previous owner has the torsion bars cranked all the way up.
Reasons for me not going sas is because i have a debt from college (graduated 2 years ago), and dont have much of the time to do it. So please don't say to sas it because that will come later on. I want a smoother ride, more travel and ground clearance. I was told to stay away from body lifts.
I want to do some 2 1/2" Ball joint spacers, and a diff drop. I'm unsure if a ball joint spacer is for travel only or if it will give my truck a lift at all.
Questions i have,
1. Does ball joint spacers give you a lift?
2. Does anyone have the measurements/link to help me make my own ball joint spacers?
3. how much of a diff drop should i do?/need to do? (if you know)
4. How do i make my own diff drop bracket?
5. Is there any other way(s) to achieve what i am looking to do without replacing major components?
Thank you in Advance!
Dan
Questions i have,
Dan
I have a 88 22re 4runner and i'm new to the 4runners, as well as ifs. This truck is my daily driver and will be until i get back on my feet. I work at a machine shop were we scrap alot of different metal, so with that being said i get my material really cheap. The previous owner has the torsion bars cranked all the way up. Reasons for me not going sas is because i have a debt from college (graduated 2 years ago), and dont have much of the time to do it. So please don't say to sas it because that will come later on. I want a smoother ride, more travel and ground clearance. I was told to stay away from body lifts. I want to do some 2 1/2" Ball joint spacers, and a diff drop. I'm unsure if a ball joint spacer is for travel only or if it will give my truck a lift at all. Questions i have, 1. Does ball joint spacers give you a lift? 2. Does anyone have the measurements/link to help me make my own ball joint spacers? 3. how much of a diff drop should i do?/need to do? (if you know) 4. How do i make my own diff drop bracket? 5. Is there any other way(s) to achieve what i am looking to do without replacing major components? Thank you in Advance! Dan
2. I'll try to find it it's around somewhere
3. You can go as low as you want but you'll lose ground clearence most kits are an inch drop
4. The kits you buy are basically a round piece of metal with a hole drilled through it
I can't find the measurements but if you look on top of your control arm you'll see the 4 bolts that hold the upper ball joint in place that's the shape you need just trace it on a piece of cardboard
What size tire do you plan to run and what do you plan to do with the truck...occasional offroad, playing in the rocks, etc? Because if you're just going after the look, you can fit up to a 33" tire by keeping it stock or going with a mild body lift of 1" and keep the IFS stock where it works the best.
Check out this thread that I posted in about Cheapest way to do a small lift to my 94 4runner." I posted links about how to fit 33's with minimal lift.
And to get to the Fab section, go here ,the forum index page. Then go to here, the Off Road Tech, Fab Shop, Solid Axle Swaps, Tool Time, & Engine Swaps section to find the Fab shop here. You have to explore the different sections of the forums here...
And check out this link about modification info...good thre
About this: "bottomed out on some rocks and i want to try to prevent that," you need to invest in some "under armor" such as rock sliders, a belly pan, front skid plate, etc so you slide over the rocks instead of getting hung up. Check out here for some good stuff...future buys for yours truly at one point...
im going to stay with my 31's but once there gone i want some 33's but my brothers went off roading and have the same truck i do and bottomed out on some rocks and i want to try to prevent that, because its my daily and i have no other vehicle and i want to be able to do more then they can do without using a lot of money./
I can climb and wheel everywhere my buddies can with their better equipped trucks; I now have a rear locker installed. Nothing wrong with running 31s.
That said, I do want to eventually run 33s, but do not want a lift, and so I'm planning on doing it with my stock suspension. It can be done, but I've heard some hammering is required. I'm gonna make it work.
I'm at work, Wyoming...I'll edit this later and see if I can help you...unless you're joking.
No problem, Dan...always want to help out.
I did the IFS lift for my 93 on a shoestring budget.
A good instructional video can be found for everything 1st Gen 4Runner related on youtube. The member to search is TheAlexManVideos. He covers his 87 4Runner mods very nicely.
BJ spacers are about $80 a pair from 4Crawler's website. They require minimal upper control arm modification to install and all new lengthened hardware is included.
The diff drop kit from 4Crawler was about $30 if I recall. Tricky to get everything lined up but if you are lucky, they slide in over an unbolted diff supported by a jack stand.
Note: the diff drop makes changing CV shafts nearly IMPOSSIBLE without dropping the diff back out completely.
Lastly, you may wish to remove your sway bar. It will allow more offroad IFS travel and has little effect on road handling IMHO.
If you remove the stud bolts for the cv axles and grind off the knurl then use blue locktite to put them back on you don't have to work so hard on the cv joints. I did this and highly recommend it use a nut and a hammer and they come right out.
Totally agree in the front sway bar. Doesn't really do much.
"BJ spacers are about $80 a pair from 4Crawler's website. They require minimal upper control arm modification to install and all new lengthened hardware is included."
Check out these spacers from Krypton Fabrications...no cutting of upper control arms necessary. Bolt on installation. They are pretty sweet. I forgot where I found their site at...
