IFS Lower Control Arm Bushing SLEEVE
Old 04-22-2008, 12:55 PM
4Hummer's Avatar
Anyone Know where to Buy the sleeve in that lives inside the lower control arm bushing?
Bought new Control Arm bushings by Poly Performance, $50.00 for the Kit. (Toyota wanted $75.00 EACH times 4 OUCH) (Bought all new Bolts, Nuts, washers, and cam adjusters from Toyota big Ouch)
Brought the Runner to an alignment shop, They had to torch off the old hardware (expected) but cannot save the sleeve. Nor can they find a Metal sleeve anywhere. Toyota will not sell the Sleeve itself.
I'm into this freaken alignment for WAY TO MUCH money now. Over $500.00 and growing (Of course they told me this AFTER they torched everything off)
Anyone ?
Old 04-22-2008, 01:37 PM
AxleIke's Avatar
AFAIK, you cannot. You have to buy the entire unit.
Your best bet is to buy old arms at the junk yard, and get the sleeves out that way, if you can.
Old 04-22-2008, 04:24 PM
4Hummer's Avatar
what the chance that
1: There is a 4Runner at a wreckers around here
2: Since I live in the Rust Belt/Salt Belt of the worlds that the junker parts are as badly seized.
Also My truck is sitting at the shop up on the host.
Anyone know the size of this Tube ? Maybe I can source the sleeve somewhere.
Old 04-22-2008, 04:42 PM
93rustedyota's Avatar
if u lived closer to me i could hook u up with a set of a arms with bushing and everything
Old 04-22-2008, 04:47 PM
Flash319's Avatar
What do they look like? I could make you some.
Old 04-22-2008, 04:50 PM
leebee's Avatar
have you talked to shane yet? he might have something that you can use and o-ville isnt that far away.
lee
Old 04-24-2008, 12:34 PM
ewong's Avatar
numbnuts...
if they had used a press and some WD40 the OEM rubber comes out of the sleeves...
The PROBLEM is that the external sleeves are pressed into the arms.
An empty sleeve will "crush" if you try to press it into the arm.
Yer better off getting a spare set of arms and gettign the bushings apart with PRESS this time.
Oh yeah - I went BACK to OEM bsuhings on mine - much happier
Old 04-24-2008, 07:04 PM
BLKNBLU's Avatar
someone on here made some. had dimensions and everything I believe. I'll noodle around some.
Old 04-24-2008, 07:22 PM
BLKNBLU's Avatar
found it
https://www.yotatech.com/forums/f116...24/index3.html
88sasturbotoy
08-11-2015 01:56 AM
kirkrunner
07-27-2015 07:59 PM
andrewtexas123
07-23-2015 11:22 AM
ksmudrunner99
07-21-2015 05:33 AM
1994toyota
07-17-2015 03:03 AM
Quick Reply: IFS Lower Control Arm Bushing SLEEVE
