IFS guys
Old 04-04-2009, 10:49 AM
desert-rat660's Avatar
IFS guys
was out wheeling today in pass canyon was climbing over some rocks that were wet and truck slid off and landed on the edge of a rock bending the left front LCA mount and the eccentric cam bolt.
Any of you guys mangle your control arm mounts?
Old 04-04-2009, 02:02 PM
Matt16's Avatar
pics or it didn't happen.
Old 04-04-2009, 04:22 PM
85excab's Avatar
u had to know this was coming!
Sounds Like a good time for a SAS!
Old 04-04-2009, 07:24 PM
tc
tc's Avatar
You bent the cam bolt? I find that hard to believe ... but if you did, WOW!
I've never had a problem with the fronts, but then I have serious skidplates up there...
Old 04-04-2009, 08:35 PM
iamsuperbleeder's Avatar
Old 04-04-2009, 09:47 PM
ill get one, im cutting all that stuff off anyways my sas kit will be here tuesday. Anybody going to need any IFS stuff after i take it out?? message me if u do
Old 04-04-2009, 10:11 PM
Justinlhc's Avatar
What kinda gears do you have in the front of that thing?
Old 04-04-2009, 10:26 PM
4.10 gearing
Old 04-05-2009, 02:47 PM
SMOD's Avatar
I have a 92 runner. I need a couple ifs axles. I dunno what kindda truck you have.. my ifs axles are the version with no hub nut that physically threads onto the axle.
Old 04-05-2009, 03:03 PM
abecedarian's Avatar
I can see bending the forward LCA mount and adjuster with a hard impact since the front diff crossmember will strengthen the forward section rather well, limiting damage to the side with the impact.
I would be concerned that the impact also bent the rear LCA mount on that side, even if you had a rear LCA truss / brace (might even have pushed the other side rear LCA mount out if you had the truss).
It's all fixable but will take some time on a rack.
Old 04-05-2009, 03:10 PM
Trustyrusty's Avatar
Show me some pictures or I'll show you a liar..
Flying91
45
04-11-2024 04:39 PM
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
scottyg486
07-19-2015 05:34 PM
timmJ
07-07-2015 02:01 PM
Quick Reply: IFS guys
