IFS front housing twisting
Old 04-07-2009, 06:18 PM
Silas's Avatar
So after last weekends big wheelin adventure having to pull a friend out i noticed i had a bit of a grinding/vibrating from the front end of the truck...( 1986 4rnr 22re auto )
Today i looked underneath with the truck in 4x4 parked facing uphill...The front driveshaft is hitting the swaybar...Hmmmm...
First reaction was to check the motor and tranny mounts, they are perfect. Hmm so i start thinking did i bend the swaybar. Go to the car was and wash off the underneath, no, swaybar and mounts are fine... Then i get a terrible feeling what if its the front housing twisting?
Sure enough, the front housing is twisting...I the front 2 half "dogbone" style mounts look fine...So i'm taking it it is the rear spaceship style mount, theres only the 3 mounts on the IFS correct?? the front two would allow it to twist like this....
So lets hope i just broke the bolt or washer thingy or something, and not the mount off the frame!!! Will update tomorrow as long as its not raining...
Anyone else ever do this???
Old 04-07-2009, 06:28 PM
abecedarian's Avatar
pics???
Old 04-07-2009, 06:29 PM
Silas's Avatar
i'll make sure to take some pics...i guess its the one mount up front and two in the back that hold the font housing in from lookin at the service manuall...this may not be good lol...
Old 04-07-2009, 06:30 PM
BigBluePile's Avatar
Huh??
Old 04-07-2009, 06:36 PM
874runnersr5's Avatar
come over to alberta and ill give you my spare ifs diff
Old 04-07-2009, 06:37 PM
4banginRunner's Avatar
Maybe just bent the swaybar?
take it off and chuck it in the scrap pile
Old 04-07-2009, 06:38 PM
Silas's Avatar
i may have a spare IFS diff..just gotta see what the gearing is in the other truck, as long as it doesn't have 31" tire option my friends not gonna use it for the gears and should be the same....
I'm just hoping its the old bolts or the mounts....not the part on the frame or housing ( though if it was housing i could live with it...)
Thanks for the offer though!!
Old 04-07-2009, 06:40 PM
Silas's Avatar
No with it in 2wd hubs unlocked theres a crapload of clearance. its only when it has pressure on it in one direction... Swaybar looks perfectly fine and i can push up on the driveshaft ( with my foot ) and move the rear of the housin up and down....the driveshaft hitting the swaybar was preventing it from moving any further...
Edit: swaybar will likely come off anyways, need a little more articulation.
Old 04-07-2009, 06:48 PM
4Crawler's Avatar
Check the 3 mounts and see where the movement is coming from. Could be the front mount is somehow damaged, either the rubber is ripped inside the mount or the mounting tabs have broken away from the lower crossmember.
Old 04-07-2009, 06:58 PM
Silas's Avatar
yea i'm pretty sure it has something to do with the rear mounts... I'll check it all out tomorrow, and take pictures too now that my digitals charged up.
i'm just hoping i dont have to bring out the ol' hobart stickmate lol
Old 04-08-2009, 05:31 PM
Silas's Avatar
Well update, pulled the front housing out today, passenger side mount broke off ( rusted ) and the drivers side was cracked from stress...will be building/reinforcing the mounts tomorrow.
Will post pictures in a bit little drunk at the moment to do so.
Old 04-08-2009, 06:09 PM
iamsuperbleeder's Avatar
lmao
you better let that wear off before you go to building new mounts too
Old 04-08-2009, 06:21 PM
Junkers88's Avatar
Originally Posted by iamsuperbleeder
lmao
Nah! Swampthing does it all the time.....
Old 04-08-2009, 06:28 PM
Silas's Avatar
well...heres a picture or two...
one of them you can see where the swaybar was rubbin the driveshaft...the other you can see the broken mount...
though i'd throw in a pic of the truck as wel ( bad one i'll take better later )
EDIT: i'll be building the new mounts tomorrow, and having a friends old man weld them in, as i'd rather not do it myself and have to fix it twice!
Attached Thumbnails IFS front housing twisting-dsc00322.jpg   IFS front housing twisting-dsc00325.jpg   IFS front housing twisting-dsc00324.jpg
Old 04-08-2009, 06:46 PM
Man that's crazy!!!
Old 04-08-2009, 06:52 PM
Silas's Avatar
Man that's crazy!!!
lol yeah oh well... i guess its expected for a 1986..we have alot of issues with rust up here....5 year old vehicles usually have some rust starting on them lol... if not sooner.
In the winter our dump trucks roll around ( in snow storms and for like a day or two after ) with only SALT in hte back...no sand, no mix of the two... just pure road salt.
Its rediculous.
Plus the design of the mount doens't lent itself to being devoid of corrosion. Its kinda like a cup therefor it would hold moisture/water/whatever in it and rust out easier.
Im not terrible concerned about it i'll fix it up and gusset it pretty good while i'm at it.
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
88sasturbotoy
08-11-2015 01:56 AM
deepmarsh
08-06-2015 03:44 AM
scottyg486
07-19-2015 05:34 PM
Quick Reply: IFS front housing twisting
