ifs front gears to front straight axle
Old 01-10-2010, 02:50 PM
toyotaman11's Avatar
just because i don't know, but will the 3rd member from my 87 ifs equipped 4runner fit my 83 front axle ? was wonderin' as i'm gettin ready to do my sas on it this week. and would like to maybe weld the gears as i don't have the funds to get a locker yet.
Old 01-10-2010, 02:53 PM
TORTIS's Avatar
I don't think so, but don't take my word for it. Front is 8.0'' on SA
Old 01-10-2010, 03:13 PM
toyminator2000's Avatar
won't fit.
Old 01-10-2010, 03:23 PM
85toy's Avatar
solid axles have 8" diffs and ifs is a 7.5" diff, but you can use a rear third member in a front solid axle because they are the same.
Old 01-10-2010, 05:25 PM
awesome ! thanks ! i'll pull the one out of my 86 rear and see if it will work. there won't be any problems with the oiling or anything else ?
Old 01-10-2010, 06:15 PM
klr toy's Avatar
the flanges have different bolt patterns from front and rear so you will have to swap that with one that matches your driveshaft. In a pinch i believe the t-case front output flange from your 86 is the same.
Old 01-11-2010, 03:31 PM
good to know. i'll keep it in mind. i'm thinking i'll probably weld the frt. gears up tho. maybe...
Old 01-11-2010, 04:02 PM
fireman1559's Avatar
woah! welding the front i know its cheap to do and it will work for AWHILE its not something i would want to keep and if you do weld a good tip to remeber is soak it in degreaser and scrub it with some sand paper and prep it really good if not...... well it can get pretty ugly ive saw a guy in a jeep i was muddin with who welded his rear and we were goin through some tuff mud and the next thing i heard was a loud boom and a clink clink thud thud..... guess what the weld broke and tore up the entire gears i ended up pulling a heep out of stuff i should have got stuck in. after joking on him for an hour or so come to find out all he did was drain the fluid and wiped it down and welded let it cool and refilled
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
ItsJustD
07-07-2015 07:49 AM
Jnkml
07-06-2015 01:20 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: ifs front gears to front straight axle
