ifs factory 4:88 swap ?s
Old 03-14-2012, 07:00 PM
runs-on-4's Avatar
i scored a ifs 488 diff from chainsaw for 80 bucks but its a little differnt than mine. there seems to be vacume lines maybe for abs or something like that. which i dont think i have.
does anyone know what the big red circled thing is
and could i just unbolt the whole right side (two small circles) and bolt it up from there
oh i also scored this for 75 bucks yesterday hopefully going in this 3rd
Old 03-14-2012, 07:07 PM
ToyoTech559's Avatar
that is know as a ADD tube. (automatic differential disconnect) you can install you non add tube. you just need to buy a seal and remove the stub thats behind the ADD tube. i just did this recently. you can see pictures of it on my build page. heres the link, near the bottom.
https://www.yotatech.com/forums/f199...9/index14.html
Old 03-14-2012, 07:09 PM
hiGis's Avatar
al the hardware that you mention is the ADD equipment, you can swap it for your manual hubs assembly (I suppose you have manual hubs and that's why you don't know what that is)
there is a lot of info right here about ADD to manual hubs conversion just use the search tool
and great score for $75 bucks!
Old 03-14-2012, 07:17 PM
runs-on-4's Avatar
thanks guys i would have tried to search but not knowing what to search for was my issue... guess i could have tried the fsm if i could find it aha..
and ya im in it at 155 for a locked 4:88 front diff.. now if i could only get a deal on the rear !
Old 03-14-2012, 07:46 PM
tacho75's Avatar
junk yard!
i paid 85 bucks for mine
Old 03-15-2012, 11:52 AM
Stuwy123's Avatar
You can also go the easy way by just disabling the ADD actuator...
Just pop the actuator off, move the slide and fork to the locked (4wd) position, seal the diaphragm air tubes with RTV, cap and re-assemble.
A little less work then swapping the shafts.
Old 03-15-2012, 01:28 PM
highonpottery's Avatar
if you do this, you'll need to use some sort of retaining system to keep the fork from sliding back to the unlocked position - on mine I used a hose clamp as a spacer to keep it from sliding back. the only reason why i did this is because my bolts wouldn't work when trying to swap tubes. read through the ADD swap threads and there's more info on this.
Old 03-15-2012, 06:15 PM
i was able to reuse the non ADD bolts. the swap is so easy tho and much cleaner look
Flying91
45
04-11-2024 04:39 PM
icentropy
09-16-2020 02:47 PM
deepmarsh
08-06-2015 03:44 AM
scottyg486
07-19-2015 05:34 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: ifs factory 4:88 swap ?s
