YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 01-19-2006, 10:10 AM   #1 (permalink)
InternetRoadkill's Avatar
Question IFS axle shaft
My restoration project has hit a snag. I discovered that the left axle shaft on the front IFS is pitted around where the inner seal rides. As a result, it's leaking oil into the axle tube extension and out the outer dust seal. :pat:
So now I'm looking for a replacement axle shaft. I would really like to avoid going to the dealer and getting ass raped. Is there another source for these, or does someone have a used shaft that is still in good condition (no pitting please).
88 4rnr,
2.4L,
auto,
1.1" splines
InternetRoadkill is offline
Sponsored Links
To remove this ad, register today!
Old 01-19-2006, 10:35 AM   #2 (permalink)
Flamedx4's Avatar
Carefull with the language, but since it was in the same sentence with 'dealer' I understand completely...
I paid $66 each for complete assemblies ready to install, lifetime warranty from Carquest.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 01-19-2006, 10:40 AM   #3 (permalink)
$66 for the axle shaft or the CV assembly? I need the axle.
Old 01-19-2006, 11:24 AM   #4 (permalink)
Flamedx4's Avatar
The whole thing.
Already lubed, with boots etc.
Like this:
__________________
Flamedx4 is offline
Old 01-19-2006, 11:41 AM   #5 (permalink)
Thanks for trying, but that's the wrong item. I need the left stub shaft that the CV half shaft bolts to.
Old 01-19-2006, 06:11 PM   #6 (permalink)
Flamedx4's Avatar
You mean the side shaft? (yellow in this diagram)
Do you have ADD or no?
Someone doing SAS should have one laying around. Check over in the Classifeds.
__________________
Flamedx4 is offline
Old 01-19-2006, 07:36 PM   #7 (permalink)
Yes, I mean the side shaft. The FSM calls it the 'side gear shaft'. I always knew it as the stub shaft.
The problem I've run into is that the previous owner never used the 4 wheel drive mode, so the oil and grease didn't get splashed on the parts inside the diff. As a result, condensation which formed inside the diff has caused rust pitting on the surface where the oil seal rides which is causing it to leak.
The dealer wants $320 for a new shaft. Not going to happen. What I'm doing now is I'm going to chuck the shaft up in my lathe and polish the seal surface to see if I can get it smooth enough to seal properly again.
As a fallback position, I'm hoping that someone who's done an SAS will have an old shaft laying around they might want to get rid of.
Old 01-19-2006, 07:39 PM   #8 (permalink)
snap-on's Avatar
Send a message via AIM to snap-on
not to dash your hopes but ive been hittin up most of the SAS guys i can find looking to de ADD my 4runner. 6 months of search has yeilded squat.
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers
92 4runner, auto, V6, OME suspension, Downey headers
snap-on is offline
Old 01-20-2006, 10:18 AM   #9 (permalink)
runethechamp's Avatar
Question
AS a side note to this question, anyone know how difficult it is and how long it should take to change the bearing for this side gear shaft? I know a got a little bit of slop in mine.
__________________
94 4runner SR5, V6 3VZE, 5 speed
Completely rebuilt engine with Toyota parts at 147k miles
Downey Coils, Aisin manual hubs, Cowl Louver mod, Hella 500 fog lights
Yeah, I know, not many cool mods here
runethechamp is offline
Old 01-20-2006, 01:24 PM   #10 (permalink)
If it's anything like the wheel bearings on the rear axle, you're going to need a good bearing splitter and a press of at least 15 tons.
The setup is nearly the same as the rear axle. To change it, you just need to remove the snap ring and place the bearing splitter under the bearing and press like crazy. You're probably going to destroy the dust shield in the process. So when you replace the bearing, be sure to use a new dust shield and a new snap ring. The new bearing will need to be pressed on with a suitable spacer underneath to support it while pressing. Don't use the outer race as a press surface when installing.
Old 01-20-2006, 01:33 PM   #11 (permalink)
Radyota's Avatar
I wonder if smearing some epoxy glue into the pitted area and fine/wetsanding it smooth would make a smooth enough, sealable surface?
__________________
'92 toyota Xtracab 4x4 pickup-3.0 v6,5 speed, 235/75 15" tires, intake "Y" hose and associated vacuum boxes eliminated,186,000 mi., engine almost together,Engnbldr's grade 10.9 head bolts, clutch now replaced w/Centerforce dual friction clutch.
'84 toyota Supra P-type 5MGE inline 6, 5 speed, 179,000 miles, RWD Ltd. slip, Pacesetter header, 5 slot mags and NO muffler.
Radyota is offline
Old 01-20-2006, 03:05 PM   #12 (permalink)
That's what I'm going to try this weekend. I have some JB weld that I'm going to coat the area with, and then I'm going to polish it using my lathe and some fine emery paper. The pits are not that deep, so there's a chance they may polish out without the JB weld.
Old 01-20-2006, 03:30 PM   #13 (permalink)
Thanks for the info.
__________________
Old 02-09-2006, 07:06 PM   #14 (permalink)
Radyota's Avatar
Did this ever work out?
__________________
Radyota is offline
Old 05-23-2006, 11:18 AM   #15 (permalink)
Quote:
Originally Posted by Flamedx4
The whole thing.
Like this:
I think my '94 4runner 194,000 miles V6 SR5 4x4 is making loud ticking noise when in 4x4 mode and steep turning. I think think the half shafts are broken or something.
The shafts that you are describing, can I install myself? Is it easy to replace and require any special tools?
How much will it cost at stealership with OEM parts?
TIA.
vkrunner is offline
Old 05-23-2006, 12:29 PM   #16 (permalink)
snap-on's Avatar
sounds like the CVs are just clicking, rebuild or replace. search CV removal for all the goodness
__________________
snap-on is offline
Old 05-23-2006, 05:08 PM   #17 (permalink)
leebee's Avatar
this might help out:
http://personal.utulsa.edu/~nathan-b...18frontdri.pdf
lee
__________________
93 sr5 v6 auto, 4x4, manual hubs, dayton timberline mt's 31 10.5 15's.
http://tlca.org # 15118
www.of4wd.com # 2270
www.phoenixrising.ca
leebee is online now
Old 05-23-2006, 06:54 PM   #18 (permalink)
Try Pirate 4x4 if you can't fix it. About 96% of the Toyota guys run straight axles. Someone sent me all the torsion bar hardware for the price of the shipping.
They just trash the stuff.
Roy
Rather Diesel is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Spindle Lubricator® for IFS axle shaft. PICTURES! toyota_mdt_tech 86-95 Trucks & 4Runners 49 09-16-2008 08:00 PM
Spindle Lubricator For IFS Axle Shaft, '86 to '95 Writeups@YotaTech Maintenance & Repair 0 01-28-2007 09:15 AM
IFS Axle Shaft super boots kit, new, bay area toy4crawlin Misc Stuff (Vehicle Related) 5 08-07-2006 09:15 PM
WTB:rear axle shaft off IFS truck (86-93) fishy1 Items Wanted 4 02-11-2006 11:22 AM
88 axle housing.........90 axle shaft....Fit? Yoda Offroad Tech 1 12-10-2005 10:36 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
