if you gonna replace a u joint should you replace bothof em
i drive a 2wd runner
im almost positive one of my u joints is bad should i replace both if im gonna do it just to make sure everything is fixed
Am I drunk at 5:24 or did that hurt the head of any one else?
If it is 2WD you only have 1 Universal Joint.
OK wait, I guess it could be a 2pt drive shaft?
I need a beer.
I need a beer.
The rear shaft has more then 1 ujoint. Inspect all the others, if they are okay then don't replace them. Make sure you lube ALL the zerk fittings on the d-shaft, there are quite a few....
James
09-04-2015 09:27 AM
