Idling issue
Idling issue
Hello, I have a 1988 4runner 22RE 5-speed. I did a motor swap and the donor vehicle was a 1995 2wd Toyota truck. I've got the 88' running but the idle is jumping from 100rpm to 600rpm and fuel is spraying out of the #1 injector. Immediately replaced the o-rings and the gaskets for all four injectors. problem remains and fuel is still spraying.
However, when I did the motor swap I am still using the intake plenum, injectors, distributor cap off the 88'. The entire bottom end is from the 95 with the exception of t oil pan and the oil pickup basically the only thing from the 95 motor is the block and the heads. any questions please ask, I will be having the injectors refurbished..thanks
it was a combination of things, changed my injectors and and the air box computer can't remember the name of it either way both came off the 95 22RE. The injectors i just modified the clip and it worked like a charm
montanatruck
02-26-2017 07:07 AM
