Idler Arm Replacement Problem
Very newbie question, but I'm fed up with trying to figure it out on my own...So I bent the crap out of my idler arm and went ahead and got one with lifetime warranty. Only problem is I can't get the stud out on the arm end. First the three bolts mounting it to the frame gave me a problem, but I got those eventually. I already checked out that link for "idler arm maintenance" and he used a pickle fork to pop the stud out. I tried that but can't get it to budge. Any other tricks or tips on how to get that thing out of there?
I'm gonna have to quote mudhippy, that worked like a charm. thanks for the help. it's amazing how quickly things go once you get that out of the way.
IDea: Make sure when using the pickle fork, have the flat-side face up, and the wedge-side facing down. Also a light coat of oil helps a bit, so the fork will have an easier go at it. yeah, it does make a difference sometimes on how the tool is held, I don't know why.
**And yeah, get a BFH. If it still wont go, pick up some marvel's or WD-40 and coat the joint, and let it sit for a bit. If it's been in there for a bit, it'll take a bit to get it loose.
EDIT: Duh, is the front end jacked up or not? *Sometimes having it not jacked gives enough free travel to aid in removal also, kinda like a re-install on the diff control arm, sometimes it just "falls into place", know what I mean?
The bushing is in case you want to just rebuild your old one, you don't get the same as far as warranty though.
They come with new bushings.
These are some manganese bronze idler arm bushings I purchased from CustomMachiningUSA.com if you were wanting to upgrade. I believe they fit 92-95 stock idler arms, not 100% sure.
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
