Is This Idler Arm Rebuildable?
Mine doesn't look like all the ones I've viewed on here with replaceable bushings.
That's the infamous Moog Idler Arm. Not rebuildable that I know of.
https://www.yotatech.com/forums/f116...er-arm-189548/
I know they say OEM on ball joints for sure here....something like an idler arm....I'd try an oem one.
Napa has the altrom one ...which is oem at a lesser price
http://www.napaonline.com/Search/Det...+50070+2070015
Get the Autozone FA5040 one so that you can run bronze bushings in it:
http://www.sdori.com/SDORI_Products.html
This page has the comparisons.
http://sdori.com/SDORI_Theory_Of_Operation.html
Stay away from these two idler arms(bushings not serviceable):
Napa ATM(Altrom)1032403(.703" shaft)
RAYBESTOS 4501091B(.703" shaft)
There's also two different OEM/stock Idler Arms for 86-95 4WDs, the 86-88(18mm/.708" shaft), and the 89-95(19.5mm/.767" shaft). Obviously you want the 89-95 if you're going to replace yours with a stock unit. But both stock versions have bushings that are readily available from multiple sources if they need replaced. Most, but not all, aftermarket idler arms have 19.5mm/.767" shafts and accept stock 89-95 idler arm bushings.
Alright, I decided to go with this one from Kragen:
http://www.oreillyauto.com/site/c/de...2853&ppt=C0203
I figured since it's only five minutes from my house, and covered for life, I'd go with it.
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Wow, a thought just went through my head...
The OEM looking one's? They get them as a core, put their sub $5 plastic bushings in them and sell them back to ppl that should have kept them for $50.
http://www.4x4wire.com/toyota/maintenance/idler/
You mean you're not going with this one?
http://www.chaosfab.com/product/acce...y4wd/95130.jpg
It's only 370 bucks...
Master Pro Chassis - Idler Arm
Part Number: K9424
Part Number: K9424
I guess you could take it back and get another one when they do wear out. Depends on what they mean by "Limited Lifetime Warranty" I suppose. But, if you get lucky and the shaft measures 18mm or 19.5mm you can use stock bushings.
Good luck!
Just for added commentary.........
I've had a Moog on my '86 4rnr for several years now. Most on road driving, but I live offroad out in the country with marginally maintained road. It's holding up well. Just keep it greased.
Hippy: Yeah, I thought about the ones known for being compatible with the brass bushings, but then I thought, heck, with Kragen being literally 5 minutes away, just throw a new one on. I can do the swap in ~15 min., so what the heck...
Besides, my offroading is fire roads and sand (not 4x4). Probably easier on it than most on this forum.
Do yourself a favor and throw that idler arm in the trash. Go back to a stock one or a '555' brand from your local auto parts place. Those moog arms suck because they dont have two areas of support, just one.
I believe that's what he's done.
BTW, what's with all this "555" talk lately? I feel like I should know what that means already. But I've not the foggiest idea.
What exactly is 555?
Another interesting note while I'm back on this subject. It's a bit curious to me that as soon as I recommended to avoid the RAYBESTOS 4501091B model, they stopped selling them on the site where I purchased one. I mean the very next day after I posted that comment I checked for them on RockAuto.com and they were GONE! And I can't seem to find them for sale anywhere now. Oh well, "good riddance to bad rubbish" I guess. Odd though. Do I really carry that much sway in the aftermarket parts world? Maybe I should bad-mouth a few other things I'd like to see disappear from the market?
