Idler Arm quick question - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 01-14-2012, 02:11 PM   #1
SR5
SR5's Avatar
If i replace the idler arm and bracket that goes with it do i need to have an alignment done? and should replace the relay rod and tie rods while im at it?
SR5 is offline   Reply With Quote
Old 01-14-2012, 02:17 PM   #2
donomite49's Avatar
i did not align or replace anything other than the idler arm. did not affect my steering.
donomite49 is offline   Reply With Quote
Old 01-14-2012, 02:53 PM   #3
MudHippy's Avatar
Quote:
1. If it's aligned currently, or was before the idler arm needed replaced, then there's a good chance you might come out aligned afterwards without having to mess with it. But if you don't know nothing about aligning the wheels, then you'll need to atleast have somebody that does take a look at it and see where it sits. And if you do that, and it needs aligned, then you're in the right place...to get it aligned(he should be able to align it if he knows that it needs aligned).
2. Why? Are they shot too?
MudHippy is offline   Reply With Quote
Old 01-14-2012, 04:19 PM   #4
mattches's Avatar
I had to replace the idler arm in mine a few years ago, and thought that I would be fine afterwards, as like MudHippy says, that if it is aligned prior then it should be after. In my case was FAIL.
It resulted in my left front wheel getting eaten up on the inside edge. I didn't catch it until the inside of the tire was bare.
I then kicked myself in the ass and got it aligned and changed out my spare tire with the pooched one. $100 later, a valuable lesson was learned... Get it checked. Most shops will actually run the alignment test and if you pass, they don't charge you!
mattches is offline   Reply With Quote
Old 01-15-2012, 12:13 PM   #5
abecedarian's Avatar
Well, the idler arm IS an integral part of the front suspension / steering system.
IF it was sufficiently worn to require replacement, then you SHOULD have an alignment done.
It directly affects toe settings and indirectly affects camber and caster.
abecedarian is offline   Reply With Quote
Old 01-15-2012, 02:59 PM   #6
SR5
SR5's Avatar
ok thanks guys ill replace it and get an alignment
so i can keep doing what i love--->
Oil Pump Question thefishguy77 Newbie Tech Section 11 08-09-2015 05:15 PM
Couple of specific water pump questions... TJWilly 95.5-2004 Tacomas & 96-2002 4Runners 6 07-31-2015 03:05 PM
Adjustable Upper rear control arms or links kirkrunner 86-95 Trucks & 4Runners 2 07-27-2015 08:59 PM
questions on buzzer and rear window function icentropy 86-95 Trucks & 4Runners 7 07-14-2015 11:23 AM
How to fix Steering linkage ptb12 84-85 Trucks & 4Runners 1 07-05-2015 02:49 PM
Tags
affect, alignment, arm, bracket, changing, failure, idle, idler, powered, replace, replacement, replacing, require, truck, vbulletin, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
