idle problem?
idle problem?
i got a 95 p/u 22re and i noticed the other day when i pushed the clutsh in to change gearas and it revved it slef up. so i thought maybe i just didnt let out of teh gas in time. then when i get to the stop sign i pushed the clutch in and my truck reved up. it wasnt constant just sounded like i was pushing the gas then lettin off, but i wasnt. and now it does it bout once everyday then stops. so is theresomethin wrong with my idle? i figure somethin mighta came loose or somethin. thank ye
most of the time when i go to start it up in the mornin, then aftrer i drive it lets ssay, 5 miles itll start doin it. and yes it does it neutral. and if im just in 2nd gear going thru a parkin lot itll give itself gas and pull w/o touchin the gas pedal
Sounds like a vac leak and the ECU is compensating by raising the idle. You can put a vac gauge on it or you can spray some starter fluid to try and find it. If this is a sudden change, you might just look around and see a hose that came off.
i havnt touched the idle any. never thought of a vacum leak thank ye. a guy that knows his stuff said it could be teh auotmatic choke kicking in when it shouldnt be or somethin
Choke is for carb'd engines. You have the fuel injected 22re. When you first start it up, the engine is cold and the idle is high, after driving for a little bit, the engine warms up and you drop to normal idle, that is when you will see the problem with the vac leak.
use carb cleaner to check for the vacuum leak, or listen for a hissing sound around the intake manifold. if u dont find anything it could be the ac idle up valve.
Jnkml
07-06-2015 01:20 PM
