idle mixture srew
idle mixture srew
hey all. just installed my weber 32/36 dgav carb on my 22r. im working on dialing it now and have run into some problems. the "idle mixture screw" seems to do absolutley nothing. the manual says to turn it in untill engine flucuation is heard and then back it out to get the leanest possible setting without changing idle. i can turn it all the way in and it will not be any different than if i took it almost all the way out.
does anyone know what causes this or how to fix it?
also if anyone has a pic of their 32/36 i would really appreciate it for a reference to what needs to be blocked off etc.
thanks a ton
Parker
thanks a ton
Parker
to b honest never had my hands on a weber carb before but if u can turn the mixture scew all the way in and it doesnt change some thing is wrong sure u got the right screw??
hmmm tell u what would probably b best search for threads under weber carbs c if u can contact someone who has been down that road before but i can honestly say ive never had a carb that didnt react to the mixture screw being turned did u try snapping the throttle a couple of times to c if it changed??
i have not ruled out vacuum leaks. in fact i bet thats what it is. i kind of ghettoized the whole thing together untill i can go to napa for some caps. some hoses have screws in em and one important looking brass capped vaccume thing has a coke cap taped onto the end of it.
thats why i would REALLY appreciate some pics of someones weber for a reference.
Blamalam
03-12-2022 07:34 AM
noosh
08-21-2015 03:49 AM
