Idle High After Rebuild. Idle Adj all the way in..
Old 03-28-2015, 10:29 PM
vsi1600's Avatar
I just rebuilt my engine, again, (didn't break in right last time), and I'm having issues with the idle.
I've got the idle adjust screw all the way in and it still idles around 1k. Every now and then the CEL comes on, and then goes off again almost right away.
The ignition timing is right at 5 but hard to know if it's good or not without being able to get the idle down.
Can anyone thing of vac hoses that could have been crossed or something that would cause it to do this? Doesn't seem to have a vacuum leak and I'm sure all the hoses went back on, but it's definitely possible that a couple of them got crossed...
Old 03-29-2015, 03:38 AM
Odin's Avatar
No way to know for sure unless you check it.
Old 03-30-2015, 07:29 PM
HappyCamper's Avatar
TPS adjustment?
I had the same issue and adjusting the TPS solved it. I used the writeup on 4crawler's site
Old 03-30-2015, 07:36 PM
vsi1600's Avatar
Thanks, I'll check that out!
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
kcaudill
07-20-2015 12:06 PM
kyletbert
07-17-2015 11:39 AM
Quick Reply: Idle High After Rebuild. Idle Adj all the way in..
