I tried Sea Foam Motor treatment today
Old 09-21-2007, 10:38 AM
4JOGGER's Avatar
Very easy to do.
I put some in the intake and crankase (half and half)
Motor was much quieter afterward.
Recommended!
Inexpensive and safe.
This Is How I Did Mine 3.old (v6)
1. There are two ways of putting SEA FOAM into the intake manifold. See hose #1 and #2 (PVC) in pics.
2. I used hose #1 which is connected from the brake booster (I think that's the term) to the intake manifold. You can pour the SEA FOAM from the brake booster end, however, I chose a different method. I disconnected hose#1 at the intake manifold end and used an extra hose (#3) of similar size that I had laying aound and clamped it down to the manifold and in the original place of hose(#1). Hose (#3) now acted like a funnel. I then used a bottle cap (#4) to cover the opening end of hose (#3) so that the engine would not die when I started the vehicle. This was the sequence:
A. I started the engine and warmed it up
B. Removed the bottle cap(#4)
C. Poured 1/2 bottle of SEA FORM down the hose (#3){***YOUR ENGINE WILL START TO STALL BUT DON'T LET IT DIE BY MANAGING THE AMOUNT OF SEA FORM BEING POURED IN***THERE WILL BE SMOKE EVERYWHERE BUT DON'T PANIC AND CALL THE FIRE DEPARTMENT***}
D. Shut off the engine and let it sat for 10 minutes. While I let it sat for 10 minutes, I removed hose (# 3) and plugged back the original hose (#1) into the manifold. I then poured the rest of the SEA FORM into the crank case via the way one would pour oil into the engine.
E. Once 10 minutes was up, I started the vehicle and drove and drove and drove until there was no more smoke coming out of the exhaust.
The engine sounded so quiet so I took the advice of TOYOTATOM93(below)and bought myself another bottle for the fuel tank.
Awesome!
Attached Thumbnails I tried Sea Foam Motor treatment today-p1010302-1.jpg   I tried Sea Foam Motor treatment today-p1010303-1.jpg   I tried Sea Foam Motor treatment today-p1010304-1.jpg
Old 09-21-2007, 11:10 AM
toyotatom93's Avatar
Ya I got nothing but good things to say about it, and I am going to do my dads corolla this weekend, hopefully the smoke will freak him out.
You should do another treatment and put some in the gas tank as well. I found after my second treatment about 3 days later it smoked even more carbon out.
Old 09-21-2007, 11:25 AM
intense's Avatar
Originally Posted by 4JOGGER
Very easy to do.
Recommended!
What hose did you use for the intake? Or did you use a hose?
The crankcase is easy enough, I'll just dump it in the oil fill on the valve cover
BTW, do you have a 22RE or 3VZE?
Old 09-21-2007, 01:53 PM
4JOGGER's Avatar
Mine is a 3.OLD. Try it. You will like it.
Old 09-21-2007, 04:33 PM
ovrrdrive's Avatar
Sea Foam right?
Just be sure you don't pour it in so fast you hydrolock the engine... I held my thumb over the PCV hose and cracked it open and just poured a small stream in front of it and it sucked it in.
It worked about as well as a bottle of STP gas treatment.
Old 09-21-2007, 04:44 PM
4JOGGER's Avatar
Hey OVRRDRIVE,
What's hydroblock?
Old 09-21-2007, 04:56 PM
OSU4Runner's Avatar
I wanna try this stuff out, but I'm kinda paranoid. I've heard it can gunk up your spark plugs and stuff
Old 09-21-2007, 05:02 PM
4JOGGER's Avatar
Nothing yet. Just quieter and smoother and better performance. My 3.OLD is more like 3.GO now.
Old 09-21-2007, 06:47 PM
ovrrdrive's Avatar
http://en.wikipedia.org/wiki/Hydrolock
Old 09-21-2007, 06:57 PM
Staff
DeathCougar's Avatar
What's hydroblock?
I believe he said hyrdoLOCK (not block) and its SeaFOAM not SeaFORM
However, since you are Canadian, we understand.
Old 09-21-2007, 07:05 PM
mjwalfredo's Avatar
I have read not to drive around too long with the sea foam in the crank case. Can anyone else vouch for that?
Old 09-21-2007, 07:20 PM
4JOGGER's Avatar
Don't dissh mee. I waz hum schoozd!!!
My ma is French and my dad is Neufoundlander and I am Chinese, therefore, give me a break y'all.
Old 09-22-2007, 05:29 AM
OSU4Runner's Avatar
Ohhhhhhhhhhhhh!!
justdifferentials
Just Differentials
08-15-2015 05:25 PM
Sidherish
08-02-2015 01:42 PM
Yota.Jay
07-23-2015 08:08 PM
94yotaky
07-23-2015 07:50 AM
Quick Reply: I tried Sea Foam Motor treatment today
