| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
94 4runner 2wd 2nd gen 3.0 V6 3VZE Auto Started this Forum AT 131,000 NOW AT 149,500 Miles I need all the help i can get i want to match the guy in the forum with the pic of 333,333 milege |
#2 (permalink) |
When i did mine, i had to do it from the inside as well. You need to manually get the window down so you can release the arms from the bottom of the window. once you get it so the arms are horizontal you can pull each slider out of the track on each side of the bottom of the window. I dont have any pics because I did this a couple of years ago. Also if you get the window down manually from the inside of the rig you can then let the tailgate down and work on it from the outside so you arent so cramped.
If you arent sure how to get the window down: get the window motor gear separated from the other gear on the lifting arm assembly and then the arms should relax and be able to move. once the motor gear is moved out of the way there shouldn't be anything holding the window up.
__________________
Link to member profile http://www.yotatech.com/showthread.php?t=117298 Last edited by SigEp4Runner; 11-07-2009 at 06:37 PM. |
#3 (permalink) |
ya i know once the window goes down the tailgat will open. how did you get the window down manually i tried prying and pulling the heck out of the sprokets to get them to move but nothing happens
i need a method to help me get the window down manually i also have pulled down on the window with two people
__________________
94 4runner 2wd 2nd gen 3.0 V6 3VZE Auto Started this Forum AT 131,000 NOW AT 149,500 Miles I need all the help i can get i want to match the guy in the forum with the pic of 333,333 milege Last edited by simpsons721; 11-07-2009 at 06:38 PM. |
#4 (permalink) |
With mine the gear was just stripped on the motor so if I pulled down on the window while someone pushed the button it would go down. But if you can get the gear from the motor separated from the assembly it will release the lifting arms allowing you to lower the window. You just have to get the gear of the motor moved enough to clear the teeth on the other gear.
__________________
Link to member profile http://www.yotatech.com/showthread.php?t=117298 |
#5 (permalink) |
ya thats what i was thinking but i havent been able to get the motor off yet hopefully tommorow does it matter if those rails are super rusted
__________________
#6 (permalink) |
it shouldnt matter, mine were really bad and I cleaned them up a little bit but they are still pretty rusty and the window works fine with the new motor. if you cant get the gear separated you could always try pushing enough to spin the motor gear so it goes down. Its been a couple years since ive seen the inside of my tailgate so i cant really remember how everything looks in there.
__________________
| Tags |
| 4runner, tailgate, window |
