I need Timing Chain Help
Old 03-29-2009, 09:26 AM
yoterr's Avatar
i need to jump my timing chain one tooth, ive been trying for like an hour and cant get it, any tips? o yeah and with the timing marks lined up the crankshafts on 12 BTDC not good right? thanks for any help
Old 03-29-2009, 09:46 AM
yoterr's Avatar
noooobody
Old 03-29-2009, 10:18 AM
874runnersr5's Avatar
yeah you need it to be 0 at TDC
Old 03-29-2009, 11:44 AM
ffryno13's Avatar
your going to have to pull the front of the motor apart and pull the cam gear off and re set it. just make sure you mark everything and take pictures. and you might want to pick up a new timeing chain because the one you have obviously is loose if it jumped a tooth. and you might want to check your water pump while your in there to see if the chain ate thru your water jacket
Old 03-29-2009, 12:59 PM
grant526's Avatar
If you're tearing into as far as mentioned above, replace the chain guides and the tensioner. They are most likely shot if the chain jumped!
Good Luck!!
Old 03-29-2009, 02:22 PM
yoterr's Avatar
got it!... had to pull the cam gear bolt off jump it a tooth and move the cam with a pair of pliers, went ahead and adjusted my valves wile i was in there and she idles smooth, but now it seems like the carb is starveing the motor of fuel, if i cover half of it with my hand it revs alot better....
Old 03-29-2009, 02:23 PM
yoterr's Avatar
oh the motor is new, was rebuilt like 8000 miles or so ago, i think the PO never had it right
Old 03-29-2009, 02:30 PM
ffryno13's Avatar
what carb do you have? if you knocked just slightly off you could have messed with mechanical fuel pump.
Old 03-29-2009, 02:42 PM
yoterr's Avatar
i got the stock carb on it, what do you mean knocked just slightly off?
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
razorman8669
07-12-2015 12:13 PM
Quick Reply: I need Timing Chain Help
