I need some help here!
Ok so I scanned the codes on my 95 3vze toyota pickup. I got a code 52 - Knock sensor signal--open or short in knock sensor signal--knock sensor/circuit ecu. The other day after the temperatures got increasingly warmer my truck was bucking and skipping like crazy, I changed the spark plugs which helped tremendously but I am confused to whether this code is telling me that the knock sensor has gone bad and needs replacing, or whether it is just detecting a knock being produced by something else in the engine.
ok thanks ill have to check that, I really don't feel like removing that intake but I guess I'll have to, while its off I need to look at my fuel injectors. Any tips on figuring out if one is clogged or not without running them through a machine? guess im going to have to dig one piece further than the intake. What is that piece called that the injectors are sitting in?
