| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
I need some advice 22r alternator problem
#2 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
should've kept the 87 alternator and wiring.
__________________
Quote:
Insomnia: it's a way of life.
#3 (permalink) | |
engine swaps should be only long block swaps. everything bolted to the original engine should be carried over to the new engine.
__________________
#4 (permalink) |
is there anyway to get around this without installing the 87 alternator and bracket?
#5 (permalink) |
Staff
No. The 83 is externally regulated, the 87 is internally regulated.
Use the 87 parts.
__________________
Tacoma miniheader install kit Now available! Click here for ordering information Need that hard to find part? Nix99 Used Toyota and Lexus parts! |
#7 (permalink) |
deathcouger is right, the 87 alternator has the voltage regulator attached, where as in an 83 its on the drivers side inner fender. the alternator should always match the harness, even the early ones that we externally regulated are wired differnt in differnt years
__________________
1979 short box. $500 special |
#8 (permalink) |
AC Delco 1 wire unit........easy and cheap fix
__________________
1992 ext.cab truck 2 wheel drive..22 RE |
#9 (permalink) |
would that be like a chevy alternator? Does the 1 wire just go to the battery and thats all the wires you have to worry about? What about it fitting the mounting brackets? I have an 87 alternator, but I think I will have to pull the motor back out to get the brackets for the 87 on.
#10 (permalink) | |
search the fora here. I wrote up a bit about wiring the alternator and which wire goes where. Not exactly a 1 wire install, but all the details.
saved you the probs- http://www.yotatech.com/f116/alterna.../#post50851269 using the 87 alt.
__________________
#11 (permalink) |
well the brackets look to hard to take off and to put back on without pulling the engine out. I think I will try to use the 87 alt and just build a new bracket using the 83 stock brackets.
#12 (permalink) |
Staff
Too hard?
You swapped an engine, but 4 bolts is too harD?!
__________________
#13 (permalink) | |
Quote:
#14 (permalink) |
no they look like they are hard to get to, and I think you have to take several other things off to get the bracket off.I dont have the truck here with me, I am trying to remember though.
#15 (permalink) |
MOD EDIT: (Lysmachia) BANNED!
X-TOOL posted 60 bannable images. Way tooo much crap.... I coulda banned all posts but I wanted everyone to see what a jerk he was. 60 posts of the same Image... I hand cleaned this one. Come on Guys! We ALL OWN YOTA's Who cares? Let's leave the fighting to the hummer guys! Last edited by Lysmachia; 07-23-2008 at 10:56 PM. |
#16 (permalink) |
What is all that about????????
#17 (permalink) |
Staff
he posted many pictures of a middle finger with "F" yotatech in the middle of it. Posted in any thread he could get in. Big dramafest last night brought to you by the Rock Winers 4x4 club.
__________________
#18 (permalink) |
what does people do to install the 1 wire chevy alternator? Do you have to fab your own brackets?
#19 (permalink) |
OK, I finally got around and installed the 87 alternator and mounting brackets and returned the truck back to stock on that part of it. I respliced the wires back to the original plug for the 87 alternator. I started the truck and removed the battery cable and the truck dies. The alternator seemed to work when I bought the truck but not 100% sure. Also, the 87 alternator has been setting out in the weather for about 2 months and has been rained on and wet. Do you think the alternator is just bad or.....? All the fuses in the black fuse box are good. Any other ideas?
#20 (permalink) |
I bought a brand new alternator today and put it on the truck. I started the truck up, and let it run for a minute. The charge light on the dash wont go off, and when the truck is running and I pull the positive cable off the battery the truck dies. What else could it be?
#21 (permalink) |
I'm not sure how thoroughly you followed the wires to and from the alternator, but check all of them, and make sure they are all good, and have good connections. I guess it is possible that water got in somewhere and as soon as current was run through it, it shorted out. That said, i would invest in a multimeter, they are like $10, that way you could figure out for sure if its the alternator or not.
__________________
88 PU, 22RE, custom bed, other random things, in the process of being restored, more or less, and driven daily..... My PU |
#22 (permalink) |
I'm suprised no one has told you yet. It's an alternator, not a generator. You need the battery hooked up to excite the windings to create electricity. It will not run with the battery disconnected. At the same time, if you disconnect the battery while the engine is running, you'll most likely burn up your new alternator.
You need to get your wiring back in order, put in a new or at least, tested and confirmed operational, alternator and quit pulling the battery cable while it's running. Good luck. |
#23 (permalink) | |
actually, it will run off the alternator once the engine has started.
it has two connections to the battery- one for the windings, the other for the regulator. once the engine has started and the alternator is producing current, it will self-excite the field windings and regulator. and that's one reason it's not recommended to do so- it can cause the system voltage to climb too high. 87yoda87- there are a couple of fuses for the alternator so make sure they are all good- in particular the 'charge' fuse, which I believe is a 7.5 amp
__________________
#24 (permalink) |
im having about the same problem in my 94 toyota pick up. When ever i turn some thing on real quick like the bright light or fan motor it makes my truck skip. when i turn the turn signal or some thing on the truck will skip to the turn signal.I took the truck up to the alternator shop and he said there was nothing wrong with altenator.Does any one have any ideas that could be causing it. i done put new wires plugs distrubture cap and button. new batterie new terminals and none of it helped.
| Tags |
| 1983, 22r, 22re, 87, altenator, alternator, battery, charge, gm, install, regulator, repair, toyota, voltage, wiring, wont |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22R/22RE GM alternator bracket | ocdropzone | Pre 84 Trucks | 2 | 03-20-2008 05:57 AM |
| 22R/RE GM single wire alternator mount | Aaronn | 86-95 Trucks & 4Runners | 20 | 03-16-2008 04:36 PM |
| battery light: I need some advice, not alternator | justanother4x4 | Maintenance & Repair Archives | 16 | 07-30-2005 03:35 PM |
| 22r Alternator Upgrade | jw | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 06-11-2005 06:35 PM |
| 22R Alternator Options? | JuttyShabango | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 06-11-2005 06:29 PM |
