I need help with front leaf hanger.
Old 07-02-2014, 06:52 PM
Do.u.even.weld.BRO?'s Avatar
Why do you have to hang leafs 1" forward and 2"down? Im going to build one but id like to get a better understanding first. 1st gen 4runner sas in progress.
Old 07-02-2014, 07:15 PM
james92toy's Avatar
I think it's because the allpro and trail gear springs are longer than stock . Also if you run bigger tires they will hit the fenders so you want to move the axle forward . The 2 inches down is for spring and steering arm clearance . When the front springs flex flat they come very close to the steering box pitman arm shaft . Also might help with castor angle. You could run less hanger drop and 1 or 2 inch taller spring . Just put bump stops so nothing hits .
PNWrider
10-30-2015 08:14 AM
shisha1999
09-21-2015 08:22 PM
88sasturbotoy
08-11-2015 01:56 AM
Backcountry411
07-24-2015 08:06 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: I need help with front leaf hanger.
