I need help figuring out my idle problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-24-2007, 09:28 PM   #1 (permalink)
ToyYoda's Avatar
Send a message via AIM to ToyYoda
First off it's an 85' model 22RE.
I just did a cylinder head swap this weekend which is also nothing
new to me because I have done this 2 times before. I have everything
installed and connected properly. I have gone over every spot that there
might be a vacuum leak and can't seem to find anything that makes a
difference although it has improved and isn't idling as crappy as it was
before. I did find a few potential vacuum leak spots but they have been fixed.
It will idle perfectly sometimes or a little too high but most of the time
it will idle like it's got some huge cam in it and sounds like a race car
as well as shaking the whole truck back and forth, then it will
eventually die but starts right back up. Then it might decide to idle
perfectly smooth?!?!
The cylinder head is brand new, even the cam. I was thinking maybe since
it's gradually improving that the cam and cylinder head just need some time
to break in.
I'm out of options at this point besides maybe going with a
different spark plug. I was finally talked into buying Bosch Platinums but now
I'm thinking that might be the problem.
Any other ideas? Maybe Idle Air Control Valve?
Other than the idle issue, the truck runs great. Doesn't burn oil, has slight
increase in low to mid range power.
Overall a problem free upgrade except for this idle issue but I did have problems
with the truck idling low after starting it warm and if it sat for a few hours, it would
take a few turn overs before it would start to idle and that was before the swap.
ToyYoda is offline
Old 09-25-2007, 08:32 AM   #2 (permalink)
ToyYoda's Avatar
Anyone? Or does no one want to read it because I typed too much?
ToyYoda is offline
Old 09-25-2007, 04:37 PM   #3 (permalink)
Throw some NGK or Denso plugs in there first. If any other plugs besides one of these is used, the engine will most likely misfire and act up.
84sr5yoty is offline
Old 09-26-2007, 08:18 AM   #4 (permalink)
ToyYoda's Avatar
Quote:
That's what I was thinking because that is the only thing I changed other than
the cylinder head which I doubt would cause this issue since it's running much
better than it did before but just can't hold a smooth idle below 1k.
ToyYoda is offline
Old 09-26-2007, 07:26 PM   #5 (permalink)
ToyYoda's Avatar
Well it wasn't the spark plugs
ToyYoda is offline
Old 09-26-2007, 08:04 PM   #6 (permalink)
Itoyota's Avatar
yeah. I wish i could have warned you. Honest, the spark plug thing might cause a minor manual stick vibration but nothing like what you are describing. If you think it's a vacum leak, check for it using brake clean, or even better a bottle of propane and a small hose to isolate the leak.
You prolly already did this, so might i direct you to your throttle body to check the TPS. If you aren't familiar with it search for it and you'll see that many of the symptoms you have are parallel with that of a tps issue. Maybe not the shaking though, so don't go out and buy a new one! If you can get your hands on an OHM meter and a feeler gauge check it to see that it's functioning properly. It's more sensitive then the valves so take care with it. I'm battling with mine right now, odd idle speed, rough idle but not to the point where the truck dies.
__________________
90 Std Cab, Honed and Bored 22re Block, Port and Polished Head, Oversized Valves, Dynomax Exhaust, 3" Body lift, SCORE raced baja light rack sporting 2Hella, 2Bosch 100W, Headlamp Conversion, KYB Gas Adjust shocks.
Itoyota is offline
Old 09-27-2007, 10:33 AM   #7 (permalink)
ToyYoda's Avatar
Well it idled ok before I did the head swap. I did have this problem to an extent but nothing like this. It would hold an idle and slowly die when it was cold but with the new cylinder head, it does it quickly. Sometimes I don't even notice after it's warm and other times I have to give it gas to keep it going. I did take apart the IACV and poked at it a little bit during the swap because of the low idle I had before. I'm thinking it might be stuck and just barely moving or not giving out the proper reading.
The MAF meter had been opened up before I owned the truck and now with the new cylinder head working better might have thrown it off? I'm still leaning toward the idle air control valve because of the low idle I had before. The thing is, it would idle after I drove around before the head swap.
I think the TPS sensor is probably working properly because I can time the truck still and haven't touched it since I bought the truck. I have seriously gone over everything that could cause a vacuum leak and can't find anything else. I've even sprayed around.
ToyYoda is offline
Old 09-27-2007, 11:11 AM   #8 (permalink)
ToyYoda's Avatar
EDIT:: Double post...stupid work computer
ToyYoda is offline
Old 09-27-2007, 03:24 PM   #9 (permalink)
Itoyota's Avatar
well if you cleaned your throttle body when you did the head with any corrosive cleaner save for throttle body cleaner (ie gas) you prolly up your tps. That's what i had done. It was nice and clean afterwards though well if your soo sure it's the AFM then you might wanna open it up, but be warned it's sensitive equipment as well and if the PO didn't mark the unmodified setting you'll have a tough time figuring out which tooth it was. Good luck.
__________________
Itoyota is offline
Old 10-01-2007, 11:14 AM   #10 (permalink)
ToyYoda's Avatar
TPS was perfect. I messed with the IACV again and my truck actually idles
more than it did before. I'm thinking the valve probably finally decided to stop
working. It does have 237k miles on it. Not matter if it's hot or cold, the valve
opening never changes...or at least, I've never seen it.
ToyYoda is offline
Old 10-01-2007, 11:28 AM   #11 (permalink)
keithguts's Avatar
Send a message via AIM to keithguts Send a message via MSN to keithguts Send a message via Yahoo to keithguts
Did you check your DASH POT, I had this problem, and it turned out to be the dashpot
__________________
IF YOU DON'T DRIVE A TOYOTA, TEST DRIVE ONE TODAY!
MY PICS
95 4runner 3.0 auto 4x4
My Rig
My Rig
RangerMan
Enjoy
keithguts is offline
Old 10-01-2007, 06:06 PM   #12 (permalink)
Quote:
Originally Posted by ToyYoda View Post
I'm thinking the valve probably finally decided to stop working. It does have 237k miles on it. Not matter if it's hot or cold, the valve opening never changes...or at least, I've never seen it.
If the valve opening never changes, then the heating element in the auxiliary air valve is fried (make sure it?s plugged in though). I fried mine by cleaning out the passages in the throttle body without removing the hose. They're a little on the expensive side, but you can get them at a discount from 1sttoyotaparts.com.
Old 10-01-2007, 06:36 PM   #13 (permalink)
Itoyota's Avatar
yeah, again have you checked your DASH POT ? You keep on mentioning this IACV and I honestly don't know what you are talking about. I have had idle issues B4 it's been my TPS the DASH POT more than once and just recently throttle cable linkage after the Body Lift. So good luck, and wish i could have been more help.
__________________
Itoyota is offline
Old 10-01-2007, 07:34 PM   #14 (permalink)
ToyYoda's Avatar
The dash pot still works and hasn't been adjusted so I'd think it would still work.
IACV is idle air control valve. This thing http://www.autopartswarehouse.com/bi...1986+1987+1988
and it's the only thing I messed with/cleaned when I swapped the cylinder head. I also did the fuel filter but I'd think it wouldn't be the problem at idle only.
ToyYoda is offline
Old 10-01-2007, 07:43 PM   #15 (permalink)
mr x's Avatar
idle return spring? just an idea.
mr x is offline
Old 10-02-2007, 04:40 PM   #16 (permalink)
It's really not an IAC valve since there is no stepper motor continuously controlling the flow of air for the idle. That's why a vacuum leak causes the motor to stumble and stall in these trucks.
Anyway......that's the proper part you posted. You can get it off of 1sttoyotaparts for cheaper than that price. I have the original Toyota microfiche slides at home and I can give you the part # for the valve later on tonight.
You'll never get the idle to come down with the valve continuously cracked open. However, there is an adjustment on side (if my memory serves me correctly, the nut is a 7mm) of the valve and it can be adjusted to where the valve never opens and is continuously closed. Your right foot will have to be the cold fast idle for the first couple of minutes, but the hot idle will be normal.
Awwwww, memories of my toasted air valve
Old 10-02-2007, 04:47 PM   #17 (permalink)
I had that problem on my 89 and there is a small coolant line going to the throttle body and i took it loose at the throttle body and blew air into it from my air compressor and it fixed it. not saying it will fix yours but it would be worth a try. I had a guy adjust my tps and i told him what i did and he said he does the same thing at the shop to fix that problem too.
edit: my idle was to high also even with the idle screw turned all the way down and the engine loped but at times it wouldn't.
highway
__________________
1989 4x4 regular cab, 22re/5-speed, Tacoma wheels/10:50's
highway is offline
Old 10-03-2007, 11:48 AM   #18 (permalink)
ToyYoda's Avatar
I suppose I'll take it all the way off and check it out and clean the passages to
see if I can save the $100+
I found a really cheap one on ebay though.
ToyYoda is offline
Tags
die, hot, out, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Idle problem starik 86-95 Trucks & 4Runners 2 06-22-2007 11:49 PM
Idle Problem timk2915 86-95 Trucks & 4Runners 1 05-08-2007 03:10 PM
up and down idle problem and blower motor problem...need help... OMX 95.5-2004 Tacomas & 96-2002 4Runners 3 11-01-2005 09:36 PM
idle problem 85TurboRunner Maintenance & Repair Archives 8 06-24-2005 04:03 PM
Idle Problem... Please Help! MAXIN 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 5 05-24-2004 08:44 AM
2009 InternetBrands, Inc.
