I need good news- Headgasket?
Old 04-29-2009, 09:18 AM
Ardent's Avatar
Ok, so this morning I was checking fluids and found something interesting. We all know that this is what clean anti-freeze looks like:
Well this is what I found in my '93 4Runner:
I got that sinking feeling that it's the headgasket. I did some searching and every "Oil in radiator" thread I looked at pointed to HG. Would someone please give me some insight? The weird thing is I've been getting better gas mileage than ever- 13.5-14 mpg. Would this explain some of my low idle issues? (500-600 rpm while in drive and stopped)
Also, is there any way to test if it is oil or just dirt? I don't know of any places around here to take a sample.
I found a 3.4L for $900 out of a 2003... but I'm really not sure that's something I can tackle. Starting my search...
Thanks for your help friends.
Old 04-29-2009, 10:17 AM
TNRabbit's Avatar
It's just old. Drain it, run only water through it for a few miles, then drain & replace with new coolant. If you had the "milkshake" look, then I'd suspect HG. Looks fine from here.
Old 04-29-2009, 10:27 AM
Staff
DeathCougar's Avatar
Looks like perfectly normal mixed antifreeze. You would likely look the same if I ran you through a water pump a few thousand times. Except red *edit so thats what they make Toyota red coolant out of!*
If you are super worried about it, just flush the system and replace the coolant. In fact, do it anyways. Cause I said so.
Old 04-29-2009, 10:56 AM
Ardent's Avatar
Great! That's very good news. Thanks for the replies and Coug, I'll do it because you said so.
Old 04-29-2009, 11:32 AM
mt_goat's Avatar
If you think thats bad you should see coolant from a Taurus after about a year of use. It just turns brown like muddy water.
coleypull15
11-03-2015 07:41 AM
Michael oaks
07-27-2015 11:47 AM
PlayAwhile
07-20-2015 11:36 AM
TURBOrunnerNM
07-20-2015 08:31 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: I need good news- Headgasket?
