I Keep breaking front differentials
Old 07-11-2010, 11:39 AM
msc_1986's Avatar
I have a 95 4Runner with 4.56 gears. They are not after market gears. I keep breaking the front differentials. The one I just blew is my 3rd one in 2 yrs and came off a 4Runner with 103K. I also have manual hubs on it as well so the axles are not spinning all the time. I ran both front and rear out of the same truck but I've never had a problem with the rear just bearings or the seal. Anyone have any ideas to why I keep blowing my front differentials??
Old 07-11-2010, 12:10 PM
scuba's Avatar
What do you mean blow?
What is breaking?
Old 07-11-2010, 12:14 PM
msc_1986's Avatar
the last 2 times it broke teeth off the ring. I'm sure its the same thing that happened again.
Old 07-11-2010, 12:21 PM
scuba's Avatar
What are you doing when this happens?
Old 07-11-2010, 12:25 PM
msc_1986's Avatar
this time i was going through some easy mud the previous time i went up a small sand hill and i cant remember the 1st time but they break under not so rough of conditions. I see people i 4wheel with do alot worse rock climbs and other things they really work their toyota's and they never have drive train issues so really don't know why I keep breaking them
Old 07-11-2010, 04:43 PM
whokrz's Avatar
I think you are cursed
The only thing I can think of is when you get your new front differential take it to a shop and have them make sure everything is to spec. I know on the 8" rear differentials the preload drops off over time making them more likely to break under stress. I would assume that the 7.5 front differential has a similar adjustment.
Old 07-11-2010, 04:47 PM
874runnersr5's Avatar
what size of tires
Old 07-11-2010, 04:52 PM
msc_1986's Avatar
I think i'm cursed to. never had a problem with the rear only the front. never seen anyone with a toyota break a differential doing the 4wheeling I do
Old 07-11-2010, 04:53 PM
msc_1986's Avatar
Originally Posted by 874runnersr5
what size of tires
34X10.50x15
Old 07-11-2010, 06:23 PM
calcuta's Avatar
you need to have have a shop put them in and start with new ones this time. most likely they weren`t set up right the rear setup dosen`t change from one housing to the other so there won`t be a problem .
Originally Posted by msc_1986
34X10.50x15
hmm most people start blowing up their diffs past 33"+.. you running after market tcase gears or duals? ever break cvs?
Old 07-11-2010, 06:29 PM
msc_1986's Avatar
all my friends run 34's and 35's on all stock drivetrain and they've never broken anything. one guyy runs boggers and his hasnt broke anything either and that trucks IFS looks scary going through rock climbs. Never broke a CV axle same original ones 248K on those
Old 07-11-2010, 06:30 PM
msc_1986's Avatar
From the factory set up wrong? all 3??? Not to sound rude but I highly doubt it. I'm putting in the whole front carrier I'm not switching out just the ring & pinion set up
Old 07-15-2010, 03:20 AM
jason191918's Avatar
and proof you use gear oil.
Old 07-15-2010, 05:46 AM
msc_1986's Avatar
Originally Posted by razed
pics of the pinion and reng gear breakage please.
I still have to take it apart its still in the truck
Old 07-15-2010, 05:49 AM
msc_1986's Avatar
and proof the rear gears are the same ratio too
I took both front and rear from the same truck 103K and of course I use gear oil I check all my fluids the night before I go out 4wheeling
Old 07-15-2010, 05:51 AM
msc_1986's Avatar
anyone know if the shaft with the actuator is a weak point in the newer Toyota trucks and 4Runner's??
Old 07-15-2010, 06:28 AM
dntsdad's Avatar
are you hard on the gas pedal while wheeling?
Old 07-15-2010, 06:37 AM
msc_1986's Avatar
Not any harder than the people I go with. They're really hard on their trucks compared to me. I've seen people do the V8 conversions and never have problems with the drivetrain (when done correctly) The people I go with do some rough rock climbs and they have never broken anything front or rear
Old 07-15-2010, 07:04 AM
lakota's Avatar
YIKEs THats a lot of BREAKING lol sucks
well all i can say if you hear it breaking hammer down on the pedal and go ouT in aBLAZE LOL
THATS REALLY FUNNY I BET IF YOUR TRUCK WAS COMPLETELY STOCK AND if you drove normally
YOU WOULDNT HAVE THESE PROBLEMS LOL
Quick Reply: I Keep breaking front differentials
