I have a miss
I have a miss
So I got my motor all put together now. It is running pretty smooth except for a few issues I am having. I'm not getting much vacuum and have a slight miss. lets talk about the miss first....
~Spark plugs are properly gapped
~Crank/Cams are timed
~Distributor is in time
~NGK plugs and wires.
I believe it is CYL 1 which is having a miss. If I pull the plug, plug #1 has less wear than the other but both were purchased new and installed the same time, same gap. Any other ideas?
Now for the vacuum lines......
On the passenger side we have these lines
The lines with the red marks on them are pulling a vacuum. But the lines with blue marks have no vacuum what so ever.
On the driver's side it's basically the same problem (Ignore the idle screw label)
Red is pulling vac, Blue is not..... Any suggestions because this is KILLING me
TheBFA
02-15-2020 06:55 AM
hiluxinargentina
09-30-2015 05:51 PM
