i hate 4wd brakes
i hate 4wd brakes
ok my rigs killin me! just did a front brake job on it and now when i hit the brakes the brake light in the dash comes on.....ive checked all the fluids and bleed them over and over again its not goin away.! if anyone has any idea please let me know somthin i put new rotors calipers and pads on so?
What bleeding method are you using?
Here's some good info on the different types:
http://www.gadgetonline.com/BrakeFlush.htm
I've never had a problem using the Power Bleeder.
AFAIK, there are two and only two switches that light is connected to - your e-brake switch (on the firewall - rod hits it when all the way down) and the fluid level sensor in the MC. For the handbrake switch just make sure it's not flopping around - hard braking would tend to drive the rod farther onto the switch so that part probably isn't the problem. But I would guess it's the level sensor in the MC. Make sure fluid is up to the "full line", that sensor plunger isn't sticking (as mentioned) and that wiring for it is good.
There's no sensors down on the pads or air sensors in the lines or anything like that.
Chris
Chris
jasonty
41
12-23-2018 01:00 PM
genuinegemini
08-03-2015 04:56 PM
ripp96
07-31-2015 11:14 AM
ripp96
07-25-2015 02:32 PM
