I got nothin'!! 22re wont start after top end rebuild
Old 08-27-2010, 04:30 PM
4xEnthusiast's Avatar
So, over the past week or so, I have been rebuilding the top end of my '89 pickup 22rE... While disassembling it, I was sure to label the hell out of EVERYTHING. Everything is back where it belongs, connected correctly, and torqued and installed correctly... I just went for the initial startup... And I got nothing but starter noises and spark noises... Any suggestions???
One thing that I thought may be an issue is the fuel lines going to and from the fuel filter... While disconnecting them to install a new filter, I found how difficult it was to correctly gauge where the holes in the bolts were comparable to the fuel lines... Could the issue be that they are not lined up correctly?? Someone please help...
Old 08-27-2010, 04:32 PM
2DoorRunner's Avatar
So is the started engaging?
Old 08-27-2010, 04:33 PM
Yes, the starter is engaging and the spark plugs sound like they are firing.
Old 08-27-2010, 04:39 PM
Check spark. Then if thats good move onto the fuel system. Just dismiss one part at a time.
Is your MAF sensor plugged in?
Old 08-27-2010, 04:46 PM
92 TOY's Avatar
is it cranking? or is the starter just clicking?
Old 08-27-2010, 04:48 PM
MAF sensor is plugged in, and how do I positively check the spark?
Old 08-27-2010, 04:49 PM
It's cranking completely, crankshaft turning, fan turning, belt moving completely, just no engine start...
Old 08-27-2010, 04:55 PM
yoder519's Avatar
so its tryin to start, just not turning over correct? im sure you did, but is the timing set right?
Old 08-27-2010, 04:57 PM
Yes, it is trying to start, everything is cranking, but it will not turn over. I believe now, after looking at it more, that it may be a fuel issue... There is no fuel making it through the lines on my throttle body. The furthest along that fuel is showing presence is at the junction between a fuel line and my upper intake.
92 TOY's Avatar
coil wire back on?
Old 08-27-2010, 04:58 PM
Oh, and yes, the timing set right. Everything is lined up correctly.
Old 08-27-2010, 05:00 PM
Coil wire is connected.
Old 08-27-2010, 05:03 PM
yoder519's Avatar
is the fuel filter on correctly? its realll easy to put them on backwards from my experience.
Old 08-27-2010, 05:05 PM
Would the fuel not get past the filter if it was on backwards? Because from what I can tell, the fuel is getting past the filter and up to my EFI body but then seems to cut off there.
Old 08-27-2010, 05:09 PM
In research, it seems as if that wouldn't make a difference as to whether the fuel would move through it. Not saying that isn't on backwards, but that doesn't seem like what is causing my current issue.
Old 08-27-2010, 05:13 PM
I dont know about the filter youre using, but some (if not all) are directional, may as well put it on the right way just to be sure.
Fuel will still flow through it, just not as well.
Have you ever taken one off and shaken it. Fuel comes out one side easier than the other.
So that may be why you arent getting enough fuel to the motor. The pump might just not have enough psi to push it through the backwards filter more than a little bit of fuel at a time.
Old 08-27-2010, 05:29 PM
Alright. I will have to try that...
Stick with me here and see if this makes sense to you... There is a fuel line that comes from under the upper plenum and into the side of the EFI chamber... This is the furthest that my fuel is getting... I believe that it may be clogged and fuel isn't getting through the piece mounted to the side of the EFI body. However, I may be talking out of my ass and have no idea what I am talking about...
Old 08-27-2010, 05:31 PM
takeitoutgetitdirty's Avatar
Crack the CSI Line to see if fuel comes out. If you have fuel getting to the the injectors than check that the ground is hooked up to the intake. Check all fuses and relays. If thats not it check the wiring harness for broken injector wires.
Old 08-27-2010, 05:32 PM
yoder519's Avatar
maybe you just got air in the fuel lines or something? jsut a suggestion, im not even sure if that can happen..
Old 08-27-2010, 06:00 PM
All fuel lines, connected to the fuel rail and injectors have no fuel in them... A friend suggested that my timing may be off......
Quick Reply: I got nothin'!! 22re wont start after top end rebuild
