Thread Tools | Search this Thread | Display Modes |
#1 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
I give up...where are they?
I've been looking for a write-up that someone posted (ovrrdrive?) that engnbldr authored on "his" procedure for installing the 22re head/gasket. I gave it two days of a couple hours searching each day and haven't found it. I do not remember what thread it was posted in or when I saw the thread, either. I've tried using engnbldr's and ovrrdrive's (I believe he/you posted it) names in the search. and it's not that I don't turn up anything, but I've tired of reading through all of the threads that it's not in.
Also, I've creatively rearranged the bolts for my timing cover (by means of dropping on the ground....duh! ) and I read somewhere at some time that someone has/had posted a write-up on where all those suckers go. I still have all of the water and oil pump bolts in there proper locations.Does anyone know where these articles of interest may be? Thanks
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
| Sponsored Links |
#2 (permalink) |
#3 (permalink) | |
One down.....one to go! Thanks a bunch, Aaronn.
I didn't realize 4crawler had a write up on the timing cover, also. What I was remembering was a different author. Moot now, though.
__________________
#4 (permalink) |
Are you talking about EB's head bolt torquing proceedure? I have that if you need it.
__________________
Dale "America is in a hole and it's getting deeper every day. We import 70% of our oil at a cost of $700 billion a year - four times the annual cost of the Iraq war." T. Boone Pickens Check out the plan: http://www.pickensplan.com/ |
#5 (permalink) | |
Two down! BAM! Rock'n'roll!
That's the one, Dale. Yes, I do need it. Thank you very much!
__________________
#6 (permalink) |
Please post up here if you can! I will be needing this in the next couple of days hopefully!
__________________
Kyle H Current Yota: 86 4Runner - Daily Beater |
#7 (permalink) | ||
Ok I saved two different wrteups by EB, here are both of them. The first I believe he was refering to the 22re, the 2nd he mentions the 3VZE:
Quote:
Quote:
__________________
#8 (permalink) |
Interesting. Great find. Thanks for posting, and thanks for EB for the info. Looking for my full top-end kit from him to arrive tomorrow!
__________________
#9 (permalink) |
Very good read indeed....
__________________
'95 4WD 22R-E 4Runner, 5spd, 205k kms, 4.56 gears, extended diff breather mod, bilstein shocks, Aisin manual hub swap, 1.25 rear coil spacer, 32" BFG's -- my DD |
#10 (permalink) | |
That's what I was looking for, Dale. Where'd you get those from?
I bought yet another HG tonight to redo this procedure. I ain't takin' chances with this step. After two months, I'm ready to be done with my rebuild......and have it last. Thanks again, fellas.
__________________
#11 (permalink) |
I saved them on my harddrive a few years ago, can't remember excactly where they originated.
__________________
#12 (permalink) |
hmmmm. learned something new today, and it is early.
__________________
89 Truck X-tra Cab LCE Timing Chain 31'' Maxxis Buckshot 4.88's built by ZUK(the mind reader) Aussie Locker Front and Rear 63'' Chevy Springs Marlin HD Clutch Bilstein HD Shocks 2.5" Exhaust W/Dynomax Muffler 2-50 Watt Backup Lights |
#13 (permalink) | |
Careful there, partner. Don't blow a headgasket.
(My joke for the day.... )
__________________
#14 (permalink) |
I posted the pic from 4crawler showing the bolt locations several times but the EB torquing procedure is a new one to me. Sounds interesting.
__________________
'95 xcab 4x4 22re,3" BL, 4" Superlift, 1.5" BJ Spacers, 36x13.5 Iroks, M/T Classic Locks, 5.29's, Rear Lockright, J and C head with engnbldr O/S SS valves, RV springs, and Crane Stage 2 cam, Magnaflow 14" with 2.25" in and 2.5" out, NGK V-Power BPR6EY's, OBA with Viair 380C and a 3 gallon tank @ 180psi, Siege Engineering Train horns - Truck bought new in Dec. '94... My buildup thread: link '03 4runner V8 SR5 completely stock |
#15 (permalink) | ||
Quote:
For some reason, I thought it was you that posted the procedure. Chaulk it up to a failed fuse in the associative memory bank.Thanks for chiming in, ovrrdrive.
__________________
#16 (permalink) |
Geez; it's about time you got that thing running again! :-)
__________________
TNRabbit Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 2006 Taco 17" Alloys, 224k miles, AISIN Hub Swap Kenwood Double-DIN Head Unit, 1x 290 watt Kenwood Amp driving 2 Klipsch speakers, 1x Kenwood 1000 watt sub amp driving 2x10" Infinity Perfect 10.1D subs |
#17 (permalink) | |
Yes, yes....I know. There's never enough time in the day. Cleaning and painting takes considerable time. Then, there's chasing bolt and bolt hole threads. Tedious. Next time I rebuild...whenever/if ever I do...I probably won't go through this much trouble to repaint. Afterall, I'm afraid the first time I get any solvent on the paint, it will come off. I was under the assumption that engine paint was more durable than what I'm seeing. Brake cleaner takes it right off. It shor is perty, though!......for now, anyway. This isn't the thread for it, but I've made "substantial" progress, but without pics I wouldn't want to bore anyone. My wife (Maniaka) has promised me she'll load them for me this weekend.Interesting note.. The diagram for the TC supplied by 4crawler doesn't account for the A/C bracket bolts on the lower RH (pass. side) corner. So, I was able to match most everything and then had to go back and rearrange a smidge for the bracket. I still have one bolt that's too short for anything. It's one of the 10mm shank bolts (12mm head). I'm wondering if I didn't accidentally mix it up with a bolt that goes somewhere else...lol. DER! I'll get it all sorted once I go to reinstalling the rest of the brackets. Then, I'll do my own diagram....painted with numbers and all. I do remember reading in a thread someone suggesting making a cardboard mock up for the TC and placing the bolts in their respective positions. That would have been too convenient, though. What's a rebuild without some struggle, eh? Ha....haha...hahaha..ha.....engh.
__________________
#18 (permalink) |
It's perfectly normal to have a box of parts left over after a rebuild.
Not saying it's good, but perfectly normal. ![]() I did the cardboard box mock up thing when I did mine. I just took a box and drew a rough estimation of the timing cover and used a knife to poke holes for the bolts as I pulled them. It worked pretty well except for a corner where I got lazy with my drawing. Seems like there was a bolt like you describe in the air conditioner bracket and also in the front top of the power steering bracket...
__________________
#19 (permalink) | |
Yeah, the one unidentified/too short bolt I have probably doesn't even go to the motor! I bet I'll find the bag of PS stuff I have has the correct bolt.
It's funny because a week ago I went to put the cam sprocket back on and couldn't find the bolt/drive gear for it. I got all hot and bothered figuring the guys at the machine shop must've not put it back in. So, I called down to the nearby dealership to see if they had one or when they could get it. Wasn't expensive (thank God), but I thought I'd double check my pile of parts bags one more time. Well......there it was....complete with a label. I think it was my clone's handwriting, though. I know I put it back in the cam! (I hate extended projects. Crap like this happens, even though it's.......normal.)
__________________
#20 (permalink) |
"pete f passed away quietly in his sleep on July 13, 2008
I'm holding my breath until I hear that engine start-up.
__________________
pete f 1989 PICKUP/3.0 VZE/3 INCH LIFT/BFG AT'S 32x11.50 ON AMERICAN RACING WHEELS BLACK 767 15x8 /AISIN MANUAL HUBS/RANCHO SHOCKS/JVC 40wx4 KDS-570 AM-FM-DISC PLAYER/KENWOOD 9 CHANNEL EQUALIZER KGC-6042A/DENON 4 CHANNEL LEVEL CONTROLLER-LINE DRIVER DCL-410/DENON DCA-600 MOS FET AMPLIFER LOVE MY RIG/2007 added Bushwacker Fender Flares and Wab-Fab Sliders SWEET "pete f passed away quietly in his sleep on July 13, 2008 Rest In Peace, Pete" |
