I forgot to reinstall the bump stops... Newb Suspension Questions
Newb Coil Install and Susp. Help... forgot bump stops..
Howdy folks,
Ya thats right, after installing new OME HD coils on my 95 Runner, I realized I had two left over bump stops. For some reason I thought they would fit through the coils once installed. Nope. I can hear you guys laughing now. This brings me to a few questions.
As you can tell, my Newb status is well established. I have very little car maintenance/ modification experience. I am a trained and licensed airplane mechanic/pilot, but the recent aqusition of my truck is my first time delving into significant land vehical repair/modification.
My questions are as follows.
1. With my new stiffer coils, are rear bump stops absolutely and immediately necessary to be reinstalled? Or, are there any aftermarket alternatives that can be reinstalled without pulling the coils back out?
2. After the truck came off the jack, I measured from the tire (BFG 31x10.5s)
to the fender and there is a full inch difference between the two sides. The left side of the truck (as viewed from behind) is taller, leaning ever so slightly to the right. I have the FSMs and reinstalled the coils as per. Whats up? What did I do wrong, what else is left to do?
3. This leads me to my next question. Are there some other components that need to installed in conjuction with the new coils? From my understanding, the Downy coils come as a kit with different brake line brackets or something.
Also I noticed that some guys have installed panhard drop brackets. Do I need this? With out the bracket could that be what is causing my lean? What about extended brake line for the new coils or addition of BJ spacers?
4. My new OME coils lifted the rear end 2 inches; what options do I have to lift the front end to match? I hear about T-bar cranks or BJ spacers. I also hear that BJ spacers can some how add increased stress on other front end components. Will 1.5" spacers and a slight crank get me back to level, with out hurting anything ? What do you guys recommend?
This is kind of a long thread, thanks for reading. All contributions appreciated.
Last edited by supercub; 06-30-2007 at 07:47 PM. Reason: Didn't like original heading
i think that you have to get the panhard bracket.. cause think about it.. you moved the axle down 2in so it really makes that bar "shorter" horizontally..the panhard is connected to the frame on the passengers side right?
Howdy folks,
1. Probably aren't critical that they be "immediately" reinstalled, but it would certainly be best to install them at some point.
2. I don't know about the OME coils for Toyota's as I haven't seen them before, however I have a ton of experience with OME coils for Jeeps (TJ's). Those are different (rear coils) for the drivers and passenger side and the coils are marked (DS, PS) with a little tag on each coil.
Are the OME coils for the Toyota's marked ?
On TJ's, installing the coils on the wrong side, will result in the vehicle not being level, side to side.
3. Shocks. Sounds like that you only installed longer rear coils.
Without installing longer shocks also, you've lost downward droop that's equal to the amount of lift that the longer coils provided. That is to say if the coils provided, say, 2" of lift over stock height, then you've lost 2" of downward droop if you didn't install longer shocks.
You may or may not need a longer brake line. Most likely not if you didn't change the shocks as you haven't changed the total travel of the rear axle.
You should get a panhard relocation bracket. I bet if you look at the truck, from the rear, you'll see that the axle is shifted to the side now and not centered under the vehicle (side to side) any more and that's not a good thing.
4. I'll leave this for others to answer/advise.
Fred
FS[GreatLakes]: 22RE performance and stock parts (pic heavy)
05-20-2016 10:27 AM
Yotadawgjr
10
08-23-2015 10:51 AM
coffey50
07-28-2015 10:55 AM
