I cant seem to find the drain plugs for my coolant???
Old 08-31-2008, 09:05 AM
toyotatom93's Avatar
The fsm points out two drains, one one the front of the rad, one sort of mid motor...I cant see them.
Old 08-31-2008, 09:09 AM
abecedarian's Avatar
the one on the radiator, should be on the engine side, bottom right
I haven't seen one on the engine, but I wasn't looking either.
Old 08-31-2008, 09:18 AM
So do I gotta remove my fan shroud to get to the rad one?
http://personal.utulsa.edu/~nathan-b...49coolantc.pdf
Hers the fsm pic that doesent help
Old 08-31-2008, 09:29 AM
MMA_Alex's Avatar
its on the lower passengers side (far) rear of the radiator. you dont need to remove anything to see it, its just a little plastic plug that you turn by hand.
when you have it out check the threads. Mine started leaking about 6 months after changing the coolant, and I ended up loosing a bunch of coolant, and making a big mess trying to replace a little $2 piece of plastic
Old 08-31-2008, 09:33 AM
Oh ok, I saw that little plastic peice, it has that drainage hose connected to it right? Now all I need is an elf to get it's hand in there.
Old 08-31-2008, 09:56 AM
MMA_Alex's Avatar
hose? no hose...just a plug
looks kinda like this
the upper part is the part that sticks out of the radiator
Old 08-31-2008, 10:30 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Ah....some do have little drain tubes coming off of them, Alex. My '92 V6 does from the factory....an ND unit.
The block drain is on the driver's side towards the rear of the motor, as I recall. You'll just have to look around for it. It's there......although probably rather frozen up.
Old 08-31-2008, 10:37 AM
Thanks all, drainage commencing.
Old 08-31-2008, 10:49 AM
Matt16's Avatar
Actually, check the little black O-ring on the end of the plug. That's what seals.
Old 08-31-2008, 11:12 AM
MMA_Alex's Avatar
I realize the o-ring is what seals, however the thread on mine was so worn down that it didn't hold in properly, and ended up coming slightly loose, which caused a slight leak. when i poked around trying to find the source of the leak I stripped what little was left of the thread holding it in, and long story short I ended up holding it on with a c-clamp so I could go to work, and then go to the parts store.
The new one is rtv'ed in place, and I won't be going that route to drain the coolant again...
MO transplant
04-23-2023 11:58 AM
steve miller
10-10-2015 01:40 AM
Johntom240
7
07-13-2015 12:18 AM
bryan34w
07-06-2015 05:53 PM
toyota32
07-06-2015 05:42 PM
Quick Reply: I cant seem to find the drain plugs for my coolant???
