I cant remove the rotor from the wheel hub.
Old 03-14-2009, 01:26 PM
FetusGoulash's Avatar
This is the worst brake job i have ever done, I am so frustrated and this is making it even worse.
Just when i thought i was in the clear i cant seem to seperate the rotor from the hub.
I have had a torch on it and a big hammer. it will not come apart.
Is it possible i have a funny year of truck that has one peice hub/rotor combination?
the truck is a 91 sr5 v6 auto (manufacture date is late 1990)
Old 03-14-2009, 01:28 PM
Tubbyfatty's Avatar
You need to take off something, forgot what its called but SEARCH, do you have the full repair manual?
Old 03-14-2009, 01:30 PM
Tubbyfatty's Avatar
your lucky im so nice, hehe jk.
https://www.yotatech.com/forums/f116...roblem-166790/
should help you out.
Old 03-14-2009, 01:31 PM
raydouble's Avatar
Is the hub and rotor off the truck?
4Crawler's Avatar
Have you removed the wheel studs? May need to have them pressed out if a hammer won't do the job:
- http://www.4x4wire.com/toyota/mainte...ont_end/rotor/
Old 03-14-2009, 01:37 PM
i searched and know exactly what i am doing but it didnt want to budge.
I finally got it out of there i had to wedge a 4' pry bar between the rotor and the hub (behind the wheel studs) and pry like a mother.
she is off now.
thanks for the quick replies!
Now to bleed the brakes.. .which sound like a major pain in the ass from the other posts i have read
Old 03-14-2009, 01:49 PM
raydouble's Avatar
Longest to shortest brake line then proportioning valve
LR,RR,RF,LF,LSPV
Flare nut wrenches if you have em', if not you should get some.
Also it is a good idea to put a piece of wood under the brake pedal and only run it though it's normal travel when bleeding brakes.
88sasturbotoy
08-11-2015 01:56 AM
coffey50
07-28-2015 10:55 AM
PlayAwhile
07-20-2015 11:36 AM
msane99
07-11-2015 08:08 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: I cant remove the rotor from the wheel hub.
