I am overheating now.
Old 09-24-2010, 12:47 PM
4xEnthusiast's Avatar
I've got an '89 pickup 22rE. Yesterday, I replaced my timing chain and I am now running ridiculously hot. Prior to changing my timing chain, I wasn't having any issues whatsoever. Everything was working perfectly. Now, I am having problems. Any suggestions?
Old 09-24-2010, 12:56 PM
camo31_10.50's Avatar
running hot as in coolant wise? or hot as in like...ambient temp hot?
losing coolant?
need to know more symptoms dude.
Old 09-24-2010, 01:28 PM
Sorry for giving such a vague description. I had taken my truck in earlier this morning to get my timing set to smog specs to pass smog. I took side streets there by habit so I didn't overheat. But after seeing that the timing was set correctly at my shop and taking it to the smog shop, I started going home and on the freeway, my temperature skyrocketed. Which wasn't the case 2 days ago, before I replaced my timing chain...
Old 09-24-2010, 01:39 PM
myyota's Avatar
Start with the easy stuff first, replace the thermostat and take it for a drive and see what happens. Did you replace the water pump while you had it a part ?.
Old 09-24-2010, 01:42 PM
andykrow's Avatar
Air bubble in the cooling system?
Old 09-24-2010, 02:38 PM
91_TOYOTA_4x4's Avatar
i second that! happens allot and an easy fix
Old 09-24-2010, 11:12 PM
HOSEMOBILE's Avatar
How do you fix an air bubble in the system?
Old 09-24-2010, 11:30 PM
joshuarobert.22's Avatar
raise the front of your truck with a jack or park on a high slope run your engine so its warm and refill your radiator with your heater on high and the engine running this helps any trapped air pockets to escape
ladybugRC
458
08-21-2020 10:41 AM
wberry85
05-17-2016 05:45 PM
primordialbeast117
12-19-2015 12:23 PM
83yotastockR
11
11-10-2015 06:54 AM
alexcarey
10-14-2015 06:05 PM
Quick Reply: I am overheating now.
