Hydrolocked 1990 22re, Guidance please
Old 03-12-2012, 02:48 PM
fire_xg's Avatar
Hey, the other day i hydrolocked my 1990 pickup 22re, i removed the plugs, cranked the motor, changed the oil, there was alot of water in the oil, water came out of the plug for about 5 seconds before oil started flowing. i got the motor running and everything, i cleaned the intake, dried the filter, cleaned the spark plugs, changed the oil again after getting the oil hot, the oil was still discolored and everything, the idle is a little rough but i dont hear anything knockin or anything, can i get any other suggestions for post hydrolock maintenace/checks. much appreciated.
Old 03-12-2012, 02:56 PM
MaK92-4RnR's Avatar
1) Snorkel if you're gonna be driving through water.
2) change the oil again until its back to normal
Old 03-12-2012, 03:37 PM
fire_xg's Avatar
yeah i plan on changin the oil again, draining and flushing the engine coolant and thats as far as i have planned..
Old 03-12-2012, 04:43 PM
WHAHAHAJR's Avatar
Wink
What happened? What did you drive through? And where are the pics?
Old 03-12-2012, 05:14 PM
skypilot's Avatar
Engine coolant is fine.
Just beware, I threw #4 rod not too long after hydrolocking mine, but that engine had 335k on it too.
Old 03-12-2012, 07:00 PM
fire_xg's Avatar
i drove through about a foot and a half deep puddle, engine shut down, wouldnt crank back up, ill post a pick of the puddle in a while, my truck has about 205k on the motor so im hopin everything goes ok...she seems alright except for an idle that sounds like its missin every once in a while, but she didnt idle too well before soo i dont know..
Old 03-12-2012, 07:39 PM
2012MongolRally's Avatar
Is your truck at stock ride height? I drove through a 1 and half yesterday and made it ok, I was concerned about this same problem happening. Keep changing that oil, and the idle gets better
Old 03-13-2012, 02:49 PM
fire_xg's Avatar
shes got a little lift and bigger tires, i hit the puddle harder than i should have, ive noticed some white smoke coming out at the exaust manifold, not sure what that meens, ill keep changin the oil and hope everything smooths out, i really hope i got lucky with this one but im doubting it.
Old 03-14-2012, 09:57 PM
X94YODAX's Avatar
Mine bent #4 rod and a valve. I lucked out, I sunk the entire front of my truck up to the valve cover. thankful that I didn't crack a head in the river. I would look into possibly a dirty injector I know my truck was previously rebuilt by my bro-in-law from sinking it and he had to redo all 4 of them. So you might have one slightly dying.
Old 03-15-2012, 12:36 PM
fire_xg's Avatar
ok, i hadnt thought of that, i could try that tho, thank you for the help
MMA_Alex
25
04-18-2017 05:07 AM
dfarr67
07-30-2015 07:08 AM
Gone Fission
07-24-2015 12:49 PM
colasurdo
07-16-2015 11:32 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: Hydrolocked 1990 22re, Guidance please
