HVAC control function doesn't change
I have a 94 Toyota 4x4, NON A/C, no matter where I put the HVAC selector, lower, upper or defrost it only blows out the upper(A/C) ducts. Any ideas?
sounds like the cable came off of the lever which moves the flaps. the FSM has illustrations of this, but you should be able to stick your head under the dash and find it.
i've had mine slip off and i put it right back on. sometimes it doesn't have to be 'broken' for it to not be working. hopefully that's the case for you.
jasonty
41
12-23-2018 01:00 PM
icentropy
07-14-2015 10:23 AM
