Hub Help - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-14-2008, 06:49 AM   #1 (permalink)
Bassmastry101's Avatar
Send a message via AIM to Bassmastry101 Send a message via Yahoo to Bassmastry101
Hub Help
Hello everyone!
I'm new here and so far I like what I see.
I know this issue i'm having might be getting old to you guys, but still I need some help. My 1986 4runner came stock with automatic locking hubs. The other day I was coming home from UGA and the front wheel on the passenger side was making this really annoying grinding noise, I figured either hub or my bearing. It got so loud that if I pull up to a red light, the people inside the store at the intersection was turning their heads. Well I pulled over and tried for about 15 minutes to get the hubs to unlock by backing up and pulling forward over and over and eventually I got them to unlock, and the noise stopped...well when I got home I guess my dirt road made it start doing it again. I pulled the auto locking hub off the passenger side , and if you shake the assembly you can hear stuff jingling around. Since i've never messed with auto hubs i'm not sure what it is. So i've read here and a few other places that you can change it to manual, and increase the life of the axles and other things. I want to know if I can just go to pull a part or something and just get manuals and just pull the autos off and swap them. And what all parts and some techniques anyone would recommend for the process. Any help will be greatly appreciated!
Bassmastry101 is offline
Old 05-14-2008, 06:59 AM   #2 (permalink)
RiNkY's Avatar
I found this helpful when I put my WARN Manual hubs on: http://www.4x4wire.com/toyota/tech/autohub/
I know allot of people plug the quality of the AISIN Hubs - but I wanted to be different!
__________________
RiNkY
87 4Runner (22re) 4x4 5spd. 1.5" BJ Spacers, 1" Diff Drop, WARN Manual Hubs, 2" Downey Leaf Springs, Skyjacker Shocks, 6" Wabfab shackles, Rear Shock Mounts & Bump Stops. Downey: Bikini Top & Sliders. Marlin Crawler Rear bumper. Budbuilt Crossmember. 31x10.5's.<br>
05 Xterra Off Road 4x4 6spd.
RiNkY is offline
Old 05-14-2008, 06:59 AM   #3 (permalink)
Belize Off Road Team's Avatar
Send a message via MSN to Belize Off Road Team
check with dirtoyboy. he can help you out alot with getting stock used AISIN manual hubs.
__________________
-Phyl
1991 Hilux Surf SSR-G Petrol 3.0L V6 196,000kms l Downey Ceramic Headers l Rancho RS5000 l 31"x10.50"xR15 Pro Comp Xterrain l TRD Air Filter
l PP 1" Lift Coil Springs l Optima Blue Top l 12" JBL Subs l Alpine Type R l 80/100W Hella H4 l Hella Black Magic l 1st Gen Roll Bar Mod l FT/RR Diff. Breathers l Smittybilt XRC8 Winch l ARB Bull Bar l
1998 Mitsubishi Montero Sport LS 3.0L V6 2WD
トヨタ|NEVER QUIT
Belize Off Road Team is offline
Old 05-14-2008, 07:03 AM   #4 (permalink)
mt_goat's Avatar
Definitely swap them for some manual hubs. Aisin hubs are the best but if you're not too hard core Warn hubs will work too.
I'm pulling off my Warn hubs now to replace with Aisin hubs so I'll sell you a set cheap.
__________________
Dale
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 05-14-2008, 07:57 AM   #5 (permalink)
Wow those replys were pretty quick. That sounds good, how cheap are you willing to sell?
Old 05-14-2008, 08:23 AM   #6 (permalink)
mt_goat's Avatar
Quote:
PM sent, here's some pics of them.
__________________
Dale
mt_goat is offline
Old 05-14-2008, 11:52 AM   #7 (permalink)
devldogs55's Avatar
I've got a set of Warn Premiums on my truck like Dales - I love 'em. They're super easy to install (though I didn't need the spline kit for your Auto hubs). Took me about 30 minutes per side to install - most of the time was taking the tires off and applying gasket to them.
__________________
1990 Yota T4R SR5
3.0 V6
5 speed manual
170,000 miles
OME shocks and 901 coils
Warn Premium Hubs
SDORI BJ Spacers
4.56 gears
Rear TRD E-locker
33x10.5 BFG MT KM2
Cherry Bomb Vortex + 2.25"
devldogs55 is offline
Old 05-14-2008, 03:51 PM   #8 (permalink)
leebee's Avatar
wabfab has them as well.
lee
__________________
93 sr5 v6 auto, 4x4
http://tlca.org
www.of4wd.com
www.phoenixrising.ca
leebee is offline
Old 05-15-2008, 06:09 AM   #9 (permalink)
This is probably a dumb question...Well the motor in my other truck just crapped out on me this morning, which leaves me with 2 front yard ornaments lol. Is it even possible to drive my 4runner without the locking hubs? Since the wheel rotates without them. I'm just not sure if the axle would slide out or not.
Old 05-15-2008, 06:15 AM   #10 (permalink)
dirtoyboy's Avatar
I wouldnt recommend Warn hubs. The design is inferior to Aisin/ASCO hubs because they dont use cone washers. I have seen many pairs (of Warns) go in the garbage..just FYI
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 05-15-2008, 06:19 AM   #11 (permalink)
mt_goat's Avatar
I wouldn't do that, you might screw up the splines on the axle. Plus wouldn't you get dirt into the CV or bearings?
__________________
Dale
mt_goat is offline
Old 05-15-2008, 06:27 AM   #12 (permalink)
Maybe if I strip the gears out of the hubs and bolted it back up? Wouldn't that be the same as manual locking hubs with them unlocked? I don't think i'm gonna risk it driving an hour to school with no hub
Old 05-15-2008, 06:33 AM   #13 (permalink)
mt_goat's Avatar
Not really, the manual hubs have a gear with bearing surface that goes over the axle splines and supports the axle when they are unlocked.
__________________
Dale
mt_goat is offline
Old 05-15-2008, 07:18 AM   #14 (permalink)
Which explains why there is a big washer that screws onto the axle...I just thought about that
Old 05-15-2008, 07:31 AM   #15 (permalink)
1stgen4gunner's Avatar
Send a message via AIM to 1stgen4gunner
do yourself a favor, ditch the auto locking hubs, and get manual locking hubs.
__________________
-Dave
"It is possible to store the mind with a million facts and still be entirely uneducated."
Sorry Guys but I am trying chevy for a while, Current Rig- 2000 Chevy S10 ZR2, but I am sure I'll be back!
1990 Deluxe Extended Cab 22RE 5spd, Roll Bar, KC Lites, Flowmaster 50 series- SOLD
1988 4Runner SR5 3.0 3VZE Auto, 31" BFG A/T KO, Bushwhackers, 205,000 miles- SOLD and was driven 4500 miles to Anchorage AK
2003 KTM SX125
1stgen4gunner is offline
Old 05-15-2008, 07:53 AM   #16 (permalink)
devldogs55's Avatar
Quote:
Warn hubs work very well. The only design flaw I can see is the nuts coming loose where the Aisin Hubs would use cone washers. That's why God invented BLUE LOCTITE! Guess what? Mine stay on there just fine. My hubs lock and unlock every time, and they stay locked when I need 'em to.
I hear claims all the time that Aisins are stronger than Warns. This may be true - but I have never seen any evidence or real support for this claim other than someone saying "I've seen Warn hubs get thrown away before."
Warn Hubs are easy to find, inexpensive (compared to reman Aisin) - and they have a LIFETIME warranty on them.
__________________
1990 Yota T4R SR5
3.0 V6
5 speed manual
170,000 miles
Warn Premium Hubs
SDORI BJ Spacers
4.56 gears
Rear TRD E-locker
33x10.5 BFG MT KM2
Old 05-15-2008, 08:19 AM   #17 (permalink)
dirtoyboy's Avatar
How much are Warn hubs? Aisin hubs are usually about 60 dollars used
__________________
Old 05-15-2008, 08:26 AM   #18 (permalink)
Maybe the motor on my other truck is damaged beyond my budget allows, because my aunt is anxious to get rid of her 96 tacoma 2wd ex cab.
Anyways, I appreciate all advice that was given, looking forward to getting some manual hubs soon! As long as my hubs don't mess up or my cv breaks, i'm fine with anykind. It's no rock crawling kinda truck, so I won't be doing anything harsh to break them.
Old 05-15-2008, 08:26 AM   #19 (permalink)
devldogs55's Avatar
The used Aisins for 60 bucks are pretty much just taken right off a vehicle - which is fine, and it's a good price. I'm the kinda guy who has to either have new or rebuilt stuff on things like this. I almost purchased a set of rebuilt Aisins but they run $250 from WABFAB. They're great hubs and look and function like brand spankin new - but I ended up spending $140 on my brand new Warn Hubs.
Nothin wrong with used though.
__________________
1990 Yota T4R SR5
3.0 V6
5 speed manual
170,000 miles
Warn Premium Hubs
SDORI BJ Spacers
4.56 gears
Rear TRD E-locker
33x10.5 BFG MT KM2
Old 05-15-2008, 08:43 AM   #20 (permalink)
dirtoyboy's Avatar
The used Aisins for 60 bucks are pretty much just taken right off a vehicle - which is fine, and it's a good price. I'm the kinda guy who has to either have new or rebuilt stuff on things like this. I almost purchased a set of rebuilt Aisins but they run $250. They're great hubs and look and function like brand spankin new - but I ended up spending $140 on my brand new Warn Hubs.
Just FYI, you can buy a rebuild kit from Toyota for about 10 dollars. It takes less than an hour to rebuild BOTH hubs.....It's actually very very simple
__________________
Old 05-15-2008, 09:03 AM   #21 (permalink)
mt_goat's Avatar
While we're on the subject of rebuilding a set of Aisin hubs here's the info I've been using and bookmarked:
http://www.pirate4x4.com/forum/showthread.php?t=281879
http://www.yotatech.com/f116/rebuild...volved-127956/
http://forum.ih8mud.com/79-95-toyota...b-rebuild.html
__________________
Dale
mt_goat is offline
Old 05-15-2008, 09:22 AM   #22 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
"Rebuild kit" is WAY misleading, as Toyota offers NO "rebuild kit" for Aisin manual hubs. Period.
__________________
WabFab Off-Road, LLC
MySpace
Twitter
Facebook
7th Annual South East 4Runner Jamboree, 2010
Thank God when you are getting kicked in the butt cause that means you are still ahead of someone.
waskillywabbit is offline
Old 05-15-2008, 09:24 AM   #23 (permalink)
Nice! Ive only seen people do that with manual hubs, I haven't been able to find anyone do a detailed breakdown and rebuild of automatic ones yet
Old 05-15-2008, 09:32 AM   #24 (permalink)
dirtoyboy's Avatar
Quote:
aye, right....by kit I mean a rubber o-ring and paper gasket...you can purchase parts to do both sides from the toy dealer for around 10 dollars.
__________________
Old 05-15-2008, 09:45 AM   #25 (permalink)
It is just much easier to get some used ones from a small town junk yard for $20 because they dont know the value. then get the new parts to rebuild it. and then you save yourself ALOT of money!
__________________
-Phyl
トヨタ|NEVER QUIT
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
hub to hub front ifs with 4inch super lift jakindle The Classifieds GraveYard 2 06-09-2007 10:33 PM
How do i get this hub off? linuxrunner Off Topic Talk 8 08-20-2006 07:54 AM
Hub noise JEDI87 95.5-2004 Tacomas & 96-2002 4Runners 8 08-29-2004 06:40 PM
Hub question fooddude Offroad Tech 2 01-19-2004 10:51 PM
2009 InternetBrands, Inc.
