How to Remove 87 Dash Pad?
Just like the title says, how do you remove the dash pad. I've got the 5 or so screws on the bottom edge of the front, but whats the next step?
there are 3 nuts on the rear.
remove the passenger side vent.
remove the instrument cover (not the cluster)
and the center one, you must give it the "reach around".
8 or 10mm nuts.
i can take pix, but im sure you can find them.
to remove the vent, i use a thin screw driver on the top/bottom corners (not the sides. and roll out.
8 or 10mm nuts.
highonpottery
7
07-18-2015 02:48 PM
