How much to rebuild tranny/tcase?
I have an oil leak in the big seals, and my first gear synchro is completely gone. Can't shift into first from a stop when warm. What would a shop charge for this?
you running a geared or chain driven case?
Good writeup here if you ever want to try yourself: http://www.4x4wire.com/toyota/tech/r151f/
check this out
It will cost about the same as buying a JDM tranny from these guys. I got an A340h from them and it works great. It has less than 50k or 60k on em and they deliver for free without a need for a core. If it is a 5-speed then here is there ebay link for that. If it is a Automatic then here is the Ebay link for that, or if you want to get in contact with them directly then there web site is www.jdmenginescorp.com .
My shop sells rebuild R150f tranns for 950$ with a 300 core. Are you using the stock chain transfer or upgraded to a gear drive? The chain cases are more to rebuild, but normally without too many mods last forever. Stock 2.28 gear case with 23 spline input goes for 795$ with a 200 core
Dale Johnston
11
10-31-2015 10:22 PM
