How much Pag and 134a for my AC?
Old 01-31-2009, 07:41 PM
qdude79's Avatar
Going to retrofit my R12 system to 134, including pulling the compressor and draining it. Already changed the drier. After pulling vacuum, how much Pag oil and 134 do I add? I've gotten VERY conflicting quotes after searching. I live in CenCal, and before you know it, it's going to be
Anyone?
TIA,
Qdude
Old 02-01-2009, 08:23 PM
qdude79's Avatar
Anyone ever retrofit/charge their own AC here???
Old 02-05-2009, 07:16 PM
small town BIG TOYS's Avatar
Google can be your friend here.
Old 02-05-2009, 07:21 PM
qdude79's Avatar
Googled extensively..
Old 02-06-2009, 08:12 AM
whorider's Avatar
Sometimes the compressor will say how much oil to use on it. Google the compressor model. As for freon, I would guess, put in what it says on the A/C sticker. It should be somewhere in the engine bay. I haven't retrofitted yet. Are you replacing the seals through out? r134 does run at higher pressure. Maybe you should consider Hot Shot an r12 direct replacement. I have heard good things about it.
Old 02-06-2009, 09:16 AM
Tubbyfatty's Avatar
I used to work at a body shop so when we would recharge ACs, they would only take a pound or 2 of R134.
I dont know about changing over from R12 tho.
Old 02-07-2009, 03:04 PM
InternetRoadkill's Avatar
If you try to charge 134a using the sight glass, the system will likely be overcharged. I found that out the hard way. 134A in an old R12 conversion seems to work better a little undercharged. I think my low-side pressure is only 25psi when running.
scope103
04-16-2020 09:01 AM
metalmadness24
07-01-2015 10:21 AM
jacked_72
09-03-2013 10:30 AM
jacked_72
08-27-2013 09:36 AM
Quick Reply: How much Pag and 134a for my AC?
