How many of y'all don't have rear bumpstops?
I have 1 rear bump stop. The other 1 is MIA. The 1 I do have is bent at a funky angle. I have a 4" bracket lift & am wondering if I need to replace the rear bump stops. If so, is there an aftermarket brand that goes somewhere outside the coil, like from axle to frame?
I cut mine down so they're low-profile now. I've had no issues running them like that with the stock springs + 2" AAL. I've also got some that aren't cut down(part of my spare rear axle). Been holding onto them just in case I ever change my mind(not very likely), or need to replace one(even less likely).
This is the best pic I could find(shows the passenger side).
Home made bump stops on my truck ^_^
Only pics i have when i was doing the wheel bearing on this side...
Spring and a mount welded to the top of the frame...
icentropy
07-11-2015 07:21 AM
icentropy
07-09-2015 02:12 PM
Vargntucson
07-04-2015 12:15 PM
