How to manually wire a toyota fuel relay
This relay came out of a 92 4runner v6, and to make a long story short i need to wire it manually. Does anyone know how to identify the pins?
Uploaded with ImageShack.us
looking at the second picture. if ur not gonna use the relay. i wanna say you jump the to top right pins on the fuse box. i looked on alldatapro and the fuel pump relay shows up as a circuit opening relay but it looks just like what you posted
If it does not show you on the relay some Toyota ones do others don`t.
Should be pretty easy to figure out with a multimeter the coil should have a resistance of between 40 to 60 ohms
The contacts should be open and read infinity if it is a good relay you are starting with.
Pins 1and 2 are the contacts
#4 is a coil coming from the air flow meter
#3 comes from the ignition switch
#6 goes to ground
pins 2and 3 are at the top with the relay held that way # 2 to the left
This has 2 coils that pull in at different times one at start and the other when it sees air flow via the air flow meter
Just what are you trying to do?
#6 goes to ground
Hmm. Awsome info. I'd like to hook the pump up to the ignition swith's on position.
I had this relay hanging around from a rig I parted out. So I figured I'd use it if I can.
If I can't I don't mind buying a generic one, but what amperage should I look for?
The fuel pump won't come on when I jump the +B and FP in the DLC1 port. The +B isn't even getting power. When I put power to the FP it fires up just fine. I have checked the ECU fuse and it seems to be working. I don't know what else it could be.
Peteyg39@hotmail.com
06-26-2015 08:15 AM
TheManOutside
06-18-2015 03:32 PM
